Stifler's Mom
MILF...MILF...MILF
- Oct 12, 2003
ROTFLMAO!!!!!!!!!!
You know it's coming.
ROTFLMAO!!!!!!!!!!
Got it! So if I were to pick a trip up in open time that another pilot submitted, I only get block and no credit.
In the case where you place the trip into open time, I assume that you are still responsible for the trip until someone actually picks it up?
If the Company has time in open time, and you pick it up, do you get the credit then? Do you guys still get time and 1/2 for open time pickup of company posted open time?
1. Yes
2. There is a window right after the bids come out where you can drop and pick up trips. After that you are responsible until someone picks it up.
3. Time and 1/2 doesn't kick in until 72 hrs before the begining of the trip. I guess you could negotiate any time period. Right now with the overstaffing, we haven't seen time and 1/2 for quite a while.
Hope that helps.
If you want days off at the front and back of your vacation how about bidding days off at the front and back end of your vacation. It's not rocket science guys. PBS has been good to me, if I had to go back to bidding lines and trying to find one that didn't suck worse than the others I think I would cry.
I think they were planning on building your line and then plugging in vaca. Then overlapping trips could be dropped. With our mmg calculations the company actually saves alot of money when we drop trips outside the vacation foot print.
With all due respect, that is not how it works. All PBS systems place the known absences on your line FIRST! Then you bid and, subsequently, the system will not award any conflicting trips--ones that overlap your vacation footprint. All awarded, or assigned trips will be outside the footprint--no conficts, no overlaps!
The main concept of any PBS system is to create additional days of Pilot availability by avoiding conflicts--both during integration and any other known non-flying absences assigned to a pilot in a month. So, to address your presumption, your known absence vacation or training event is plugged in first, then you bid, and the system is designed not to award trips that overlap or conflict with those events or any other known absence.
Another misunderstood concept, at least partially, is PBS does not favor only the Senior pilots on the Seniority list. Within each position bid, trips are awarded, at least to some degree, relative to the Seniority in those bidding positions. At ASA, there are 4 different position awards. As an example, when the program runs the CR2 F/O award, the the awarding of trips to build a line, will be executed in Seniority order, within the CR2 F/O position. This is really no different than how things work today. You can get what your seniority will hold when the bidding program gets to you.
However, some of the earlier systems work on a Global Solution, whereas, the software goes through the bids, and in the ends awards trips, not necessarily on Seniority, but what is best for an overall solutution--a benefit to the Company. AOS is an example of this type system. The latest system(s), one but maybe partially 2, award trips like lines are awarded today--seniority within each position.
In the end, in any system, you have to understand how trips are awarded, what your seniority will hold, and learn how to properly bid for that system and your seniority. Under some of the earlier systems, you may not always get what you want, even with your seniority, and if through your bidding, if you can't hit the target, then the software will award you a trip(s) so that it gets you to the target.
PBS is more complicated for the Pilot in the bidding process. However, if a Pilot learns to bid, he can actually be awarded a line that is much better than he could ever get under line-bidding. The burden is on the Pilot.
Airlines can negotiate changes to PBS. Technically it would not be hard, just drop what conflicts. And I was told ASA was working towards this option because pilots lose a lot of money, and the company saves, with MMG formulas. But if PBS is dead at ASA then it's not worth getting your drawers in a bunch.
I'm glad it's dead if in fact it is.
