Highest altimeter setting you've ever seen?
User546
The Ultimate Show Stopper
Whats the highest altimeter setting anyone has been given or flown with before?
While checking the weather this morning for a trip, I noticed the local altimeter was 30.58. I've never seen it that high before, so it got me wondering!
Yesterday, Nov 14., it was 30.75 over most of Md. and parts of Va.
Saw 30.82 yesterday.
Highest I ever saw was 30.96 or 30.94, one of those two. Wintertime in NY, probably winter of 99/00.
30.80 a couple days ago in DTW
Boy, this ought to stir the pot...it has been over 31.00 here in the midwest a few times in the last 30 years or so and low altitude ATC is shutdown when it is that high. I'll let you find the reference as to why that is so...have at it, guys and girls.
Higher then 31.00 would mean a NOTAM would be issued to restrict IFR flights??? Am I close??? Also... is it possible to set your Altimiter for pressures higher than 31.00???? I didn't think the "standard" Altimeter went that high... (saying that... never tried).
sandslob
www.lifeisabeach.us
Pretty close...they stopped all traffic, including VFR, for about 24 hours 'till the High moved on. Very unusual until 9/11, that topped it. <g> And yes it was by NOTAM.
30.68 in SBN on Sat701EV
sandslob
www.lifeisabeach.us[/QUOTE]31.00 is the top of the scale for most altimeters. One of the reasons for stopping everything is the non-standard pressure lapse rate in such a cold dense airmass. Standard quadrangle altitude separation would be meaningless and obstructon clearance would suffer. There are ways around that but not usually used in the lower 48.
31.08
Feb 1980 McGuire AFB, and yes there were restrictions on flight. It was severe VFR.
It was 30.77 yesterday in CYXU. That was the highest I have ever seen.
The highest pressure ever observed in was at Sedom, Israel (elevation -1275 feet) on 21 February 1961: 31.94 inches (1081.8 mb).
However, adjusted for sea level, that's only about 30.65.
Donsa320Boy, this ought to stir the pot...it has been over 31.00 here in the midwest a few times in the last 30 years or so and low altitude ATC is shutdown when it is that high. I'll let you find the reference as to why that is so...have at it, guys and girls.
§ 91.144
Regards
ive seen 30.67 and a low of 29.03 in lga 2 yrs ago xmas eve....during a noreaster.....that was a fun night...1800 rvr blowing snow amd 40 mph winds....they shut the airport down at 830 at night.....
Highest 30.95 a few years ago. This thread got me thinking about lower than standard altimeter settings and non-availability of the lower flight-levels. Anyone know off the top of their head, at what alt setting that happens?
-Stepclimb
-Stepclimb
At 29.91 FL180 is no longer available.
Stepclimb,
29.92 or higer: lowest usable FL is 180.
29.91- 28.92: lowest usable FL is 190.
29.81-27.92: lowest usable FL is 200.
This is based on Canadian regs, so I am not sure how these compare to the FAAs.
uwochris said:
Stepclimb,
Slight mistype there, eh, on the last one. Other than that, same as U.S.
