Ace-of-the-Base
- Sep 16, 2004
Dumbledore said:How's about trying it in an airplane that was built for the job. A Hawker isn't one of them - XP or not, winglets or not.
You have to ask yourself just one question:
Do you really want to be sweating the fuel for SIX hours?
You're right, the Hawker wasn't designed for this sort of flight, neither was the 737. They both can do it safely under the right conditions. The reason there is so much discussion is that there are a lot of amature jet pilots on this board. Do I really want to be sweating fuel for six hours? Don't know if I want to, but I'm going to (and have several times in each jet I've flown). I don't call it 'sweating' though. I call it cutting into my planned reserve. Legal and safe. I've done it in a Lear and I've done it in a GV. If you don't want to take a jet to its range limits, you should really be letting the pros fly the things.
As for those flight plans that someone ran, 2 comments. 1. That plan is not optomized for the tail number to be flown (could make it better or worse). and 2. Landing with 1:12 (1400#) seems like plenty of fuel in a Hawker. Its over 10% of the total fuel capacity. Look up 121 regs (worse than part 91) and you'll understand. Of course, I haven't seen the drift down so I can't comment on that.
Ace
