Gotcha! – Teterboro, NJ (KTEB)
diggertwo
From http://www.pilotbug.com/?p=1549
When on the VOR DME-A, Circle 19 into Teterboro (KTEB) watch out for the minimums. While the circling minimums on the approach plate indicate 1000′, you might be surprised to find out that you will be instructed to remain at 1500′ by the tower. This is usually to provide separation from helicopter traffic, and can get you in trouble if you are not prepared for it.
The above is intended to be advisory in nature and does not supersede any information contained in the FAR’s or AIM. Every situation is different and may not apply to every flight.
Been like that for years. Not sure how this is a "gotcha". 95% or more of the many, many VOR-DME A approaches I've done into TEB were in much better than basic VFR wx minimums. And now it is pretty much a moot point. Since they commissioned the ILS 19 they've all but phased out the VOR-DME A.
Yup. I agree. Done hundreds of these and I don't ever recall not being told "cross TEB vor @ 1500' circle to 19" as part of the approach clearance.
Got this.
Here's a couple more gotchas... mandatory altitudes on the ILS 6 and VorDmeA. Oh, yea and DO NOT fly over Teaneck on Wednesday afternoon 10/21/09! Check your TFR's.
All these "gotcha" have been in place for years (with exception of the TFR). I also hear there is a hospital that likes you to keep it quiet!
Mr. gotcha!! I can sing this song 3 times a day since is probably how many times a day I am at TEB….
Example:
Pilot: Teterboro tower N123XY is on the VOR DME A approach 5 miles out
Tower: N123XY after CLIFO descend and maintain 1500’ proceed overhead the airport left traffic runway 19. Extend your downwind I’ll call your base!!
Pilot: N123XY will proceed overhead the airport left traffic for Rwy 19
Tower: N123XY, you can turn your base now runway 19 clear to land use caution with the ABC antenna.
There you have it my friend (gotcha) old news!!
I guess I posted this in the wrong category. The intention was to alert newbies of this. The blog also has other "gotchas" from around the country. As fractional pilots, we can't know every airport detail and a little heads up should always be welcome.
I'll tell ya a "gottcha"
KDTS
Non towered field...but don't just take off VFR.
It's inside class D airspace so the minute you rotate you just entered class D without talking to the tower first.
KDTS
http://www.airnav.com/airport/KDTS
Additional Remarks
- RWY 14/32 HAS A 200' STOPWAY BOTH ENDS.
- EXERCISE EXTREME VIGILANCE DUE TO CLOSE PROXIMITY TO EGLIN AFB LCTD 6NM NW OF ARPT.
- ALL ACFT CTC EGLIN CD ON 121.6 OR 127.7 FOR ATC DEP INSTR PRIOR TO TKOF.
- IFR ACFT REMAIN ON GROUND - CTC DEP CONTROL FOR CLIMB OUT INSTR AND IFR RELEASE.
Yeah, I guess you're right. Along with every other pilot, I always check airnav.com before I fly so I suppose this could never be a problem...my bad.
...sarcasm off
Oh, and to any normal pilots out there, there are little signs by the runway too so look out for them as well.
KDTS
Not quite inside the Eglin Class D but you need to stay below 500 ft if taking off to the north. South ops you can go VFR without talking to Eglin but they don't like it.
Here's a tip if you're going west and want to avoid CEW. File the coast (Varre or Tradr) at 10000 or below and you'll get your routing then 10 minutes later when talking to PNS dep ask for higher and you'll get it. Saves time and gas.
You know its good this thread, because there was once a time when it was our first time into TEB. And even though I was flying 4 times a week into TEB from Chicago at one point, I joined a company that always sent me to the west coast, and the first time I went back to TEB that restriction on the ILS for the descent got me.......although I never understood the hoopla about the departure that was always made. Iit was and is pretty straight forward and I never saw or heard of anyone doing it incorrectly.
I think any newbie to TEB will appreciate this thread, although I dont think Fractional pilots is the place for it.
That is not true and is why I posted it. Eglins Class D extends out and around KDTS.
KDTS in INSIDE Eglins Class D and it goes right down to the runway. If you rotate and climb 1 foot without contacting Eglin for clearance then you have just entered class D without radio contact. I think there may be a FAR covering that.
Here's a link to a picture of the sectional with the airspace in question. See how the dashed blue line goes out around KDTS?
click for KDTS airport with Sectional
Watch out out there...
You must be a NEWBE or from the West Coast.
There's a lot more pr!cks in the frac section, you should try the corporate forum, they're a lot more reasonable.
Don't let the "skygods" get you down digger...
You never know the newb you may have helped.
Yeah, I'm never too proud to learn something. Obviously there's a lot of folks who haven't gotten all the low down on TEB as there are several violations per week handed out according to a local pilot I spoke with a few months ago. I think one of the ILS's has a crossing limit that you'll bust if you fly the g/s from outside the FAF. Good luck.
There is nothing to LEARN.
You just have to know how to READ.
5% ers screwing this stuff up and then the rest of us have to pay and WAIST time in the sim on this BS
Perhaps that should be WASTE...... or do you need to slim down??? :p
Quite some while ago, I believe NJE (& perhaps NJI?) provided the relevant information to KTEB authorities from our flight data monitoring programme to show how many unstable approaches were caused by the circling procedure (a very high %). The feedback to our crews was that this was significant in changing KTEB procedures.
Oh, reading is all well & good, but when ATC hit you with an "unexpected" option that is not written down, but often instructed & well known to local or regular operators, then I'm always thankful if I can get a heads-up from other informal sources.......
VOR Approach with the Circle to 19 is another easy approach. Tower tells you to cross mid field at 1500 and then you enter a normal downwind, base and final. This is Private Pilot Sh*t
Nifty aid I found on the overhead circle is set your AOA to 1.5 and that gives you a green doughnut at ref and 20 when configed for circling (usually flaps 20 in most jets). That way you can stay heads up and reference the indexer for speed. Pile on....
Nifty aid I found on the overhead circle is set your AOA to 1.5 and that gives you a green doughnut at ref and 20 when configed for circling (usually flaps 20 in most jets). That way you can stay heads up and reference the indexer for speed. Pile on....[/QUOTE]
Pile On.....
Pile On.....
This is FI after all, I don't expect to make a comment without someone piling on. That's half the fun of this dysfunctional little community. :smash:
Surely someone can find fault with my logic/math/technique (it works in the Hawker for a fact).
Its about as dysfuntional as a pilot not being able to fly a VFR pattern to land on 19 at TEB
I stand corrected. Thanks for the sectional link. I'm always IFR so I don't pay as close attention to the VFR sec as I should.
And that's what makes it a "gottcha"...the reason I posted it.
be careful out there...
