any damage to the main pax door seal area, usually caused by closing door without red strap attached
ground straps:
main pax door - under top step on right side
all access panels
all gear door panels
under spoilers and spoilerons
ailerons and flaps
any holes in radome clear adhesive cover
hairline cracks in main pax door hinge
aileron and flap seals
caulking required around outside of nav light housing
chain that holds gas cap on
any dings or significant scratches on leading edge
any dings or scratches on fan blades
Placards that are commonly missing or damaged:
oxy door
nose gear door
adg door
Any cut in tires. Don't be a mechanic and dig into the cut to try and find chord, that is not your job. Have a mechanic sign off on it even if you're at an outstation.
Oil splatter on FDR, viewable from vents at very rear behind aft equip bay door.
Cockpit:
2 replacement fuses behind FO are always broken/missing.
visible moisture coming from air vents means the "socks" that filter the air are old and moldy. If captain says anything otherwise tell him you refuse to breath moldy air all day and you're writing it up whether he likes it or not. This is not a joke, ask the mechanics to show you the sock and you'll know what I mean
all cockpit lights must work
yoke writing pad angle adjustment is always busted.
don't fly with 7 year old seats that are so uncomfortable you need a chiropractor after a day of flying
any and all unusual status and caution messages on the taxi out. You should NOT feel comfortable with your captain pulling out his dandy magic circuit breaker list. It is not his job nor yours to pull circuit breakers unless directed to do so by mx or emergency.
NOSE WHEEL SHIMMY ON TAKEOFF!
I had one shimmy once, wrote it up and found that it had not been installed correctly.
It is also extremely important to understand that a discrepancy is a discrepancy whether you find it at C23 or at an outstation. Do not wait until "we get back to atl" to have something checked out. That is why we have outsourced mx at outstations.
Besides safety, another good reason to follow this rule is that it has happened numerous times where the FO will do the walkaround, only to have a fed preflight after the FO and find things wrong.
It is not worth the risk, and our company has acknowledged and reinforced that strongly by the latest bulletins stating that ALL discrepancies MUST be written up.
