heywatchthis
- Feb 28, 2005
BOHICAgain said:FAF on an ILS is lowest published altitude at glide slope intercept. SO if they clear you at 10000 feet your FAF the lowest published altitude. If they clear you below the lowest published altitude it is at whatever altitude you intercept glideslope..
CORRECT. Better stated. "Lowest published altitude" that is on the approach chart. But if you intercept the GS below the "lowest published altitude" then that is the FAF.
RECAP!!
If you intercept ABOVE "lowest published altitude" - FAF is once your at the Lowest published altitude.
If you intercept AT "lowest published altitude" - That is the FAF.
If you intercept BELOW "lowest published altitude" - That is the FAF.
The FO in the interview is wrong or you misunderstood him.
