Gear Horn Below 150 kts
hawkerjet
Total Time
8200
Could someone give me a quick refresher as to why the gear horn in a Hawker will sound if you have flaps and no gear down and speed 150 and below. Then why doesn't it sound on takeoff????
I have a brain freeze.....
semperfido
Keep Humpin
Total Time
11K+
hawkerjet
Total Time
8200
That part I understand, what is confusing me is why will the horn sound with flaps 15 and no gear down and 149 knots on approach, BUT NOT in Takeoff configuration when you get the gear up after takeoff and are still below 150kts
semperfido
Keep Humpin
Total Time
11K+
power lever position?
...just guessing
hawkerjet
Total Time
8200
Thanks, I'll check that out. There is a PLA section in the AFM I need to dust off....
pilotgolfer
Total Time
7500
Next time on climb out, pull the power back to idle and see if the horn goes off
MauleSkinner
Total Time
10,000
Yup...there's a thrust lever position interface (90%?) in the Hawkers, among other airplanes.
Hawker800
Total Time
5300
If I recall correctly, power levers below 60% N1, flaps 15, no gear down, 150kts = horn. That horn will wake the dead. Anyway Happy New Year everyone all the best.
NCherches
Total Time
5000+
wow... Usually throttle position, flap settings and usually indicated airspeed are influences on when the horn sounds in ANY aircraft....
Flaps to full or land should ALWAYS sound a gear horn and usually flaps at approach or around 15* a low throttle position will also sound it.
