Game On
dime line
Well, we heard it from the cats mouth during last nights Flops union telephone call in. The company is calling our Bluff.
If your not paying your dues....Its gonna be mighty uncomfortable being on the road for 8 days.
To you Flops pilots not paying your dues....GAME ON
To you New hires.....You made your bed the morning you told Flops "YES ill take the job"....no bichn....GAME ON
To Flops management, You don't want to pay industry wages, fine, your gonna get Kmart work out of us. ...GAME ON
To the industry, Flops might be here today, But if managements "Game ON" plays out, we will not be here tomorrow......GAME ON
B19 get your resume together, might be #3 for you. Your right, "the company will get the union it deserves".
GAME ON, GAME ON
For those of us who forgot how, here are a "Few" items that will help you through your day, and keep FLOPS prosperous (for today, that is)
HOW TO PRE-FLIGHT A BEECHJET​
1. Power lever gators (the rubber that keeps stuff from falling into the pedestal) needs to be intact not worn downing item
2. Bonding cables under the spoilerons
3. Top of brake calipers for leaks
4. Plastic conduits for wires for the main gear for fraying and damage
5. Hydraulic lines that go into the pressure switches below the reservoir (mx might try to get you to leave a rag in there for the next flight to check for drips. this is unsafe and illegal) don't even reach in to wipe them (I can't reach them anyway and I have slender long arms)
6. Missing rings/washers on the air stairs, or safety wire, safety wire is not per the BJ MX Manual
7. Nose wheel steering pin for a frayed cable (hazard as it might cut your fingers)(puncture wounds by sharp metal are especially prone to infection)
8. Pitot tubes for worn coating
9. Elevator horn coating (check with control lock installed for more thorough viewing)
10. Door seal channel for damage from door pins
11. Move all pax seats for free movement and locking (check for shoulder harness placards, including the lav seat)
12. All placards (exterior and interior) installed and readable
13. Michelins are installed instead of Goodyear’s, check sidewalls for wear as they are slightly wider and often rub while spinning down in the wells shortly after gear retraction
14. Seat belt extender placards for compatibility with seat belt systems with shoulder harnesses
15. O2 mask microphone function
16. Accumulator window too hazed to see through
17. Broken safety wire on emer gear/door/brake handle
18. Burned out fuel/hyd shutoff valve lights
19. Takeoff pitch trim horn doesn't sound if trim is SLIGHTLY out of the green
20. Takeoff pitch trim horn does sound if trim is BARELY within green.
21. Aileron trims run at different speeds.
22. One aileron trim hesitates partway through full range
23. O2 mask smoke clearing device broken
24. O2 mask weak pressure for inflating halo
25. O2 mask does not stay in cradle.
26. Smoke goggles too scratched/dirty to see safely.
27. Smoke goggles cover(s) missing/damaged.
28. Check for slippage on the engine inlet screws
29. Static and pitot drains are closed
30. Fire extinguisher properly charged
31. Cockpit trim indicator agrees w/ trim position marking on vertical stab
32. Cracked static wicks can be hard to spot without a gentle tug
33. Non-LED rear nav lights have a short lifespan
34. Drain holes under horizontal stab are clear
35. bonding cables under the spoilerons
36. Allowed, two degree's of roll per second when selecting flaps 10
37. Missing LED's on the clocks (No IFR)
38. Check the knife valve on the crapper. It is MEL-able, but a real live mechanic must come out and disconnect the electrical
39. Missing screws around the access panels ... found one plane missing 28!!!
40. Feed back from the hand held mikes. It’s a no no
41. Foil coated Fire retardant blankets in the main landing gear wells. Torn, punctured or missing the foil coating? This is a downing item according to QA. Not MDL’able
42. Engage the autopilot prior to doing the stall test. When the stick shaker comes on, it MUST also disconnect the autopilot.
43. Run your elevator trim full down and full up. If the needle pass the RED limit marks ... broke
44. On battery power only, run your rudder trim from full right to left or visa versa. The rudder must have full travel in less than 64 seconds per the mx manual
45. When selecting flaps 30, be sure they indicate 30, not 29 not 31 ... can you tell me what REF is for a flaps 29 or 31 approach
46. Big Dents under the door from stair malfunction. Must be measured with a caliper, That area is pressurized
47. Nose strut bottoming or bouncing on taxi, nose strut to low
48. Main door handle. If it lifts up without pressing the red button your done
49. Cabin door closed, the "Red" markings for the door pins must be "Completely Covered". This is listed in the AFM
50. All of this because, SAFETY, SERVICE, AND PROFITABILITY
Dont Work Overtime
Dimeline,
Thats all good. But, until the majority of the ranks understand something as simple as DONT WORK OVERTIME, we are F$%#ED. I don't understand it. If pilots weren't doing overtime FLOPS could not meet their crewing needs and planes would be parked. Its like the majority of pilots dont care or something. Right now we are losing the battle because of a complete lack of solidarity. It is very obvious to management, that is why they are dragging their feet in negotiations. Its pathetic. If we could get some solidarity we could bring this thing to a conclusion. But to me at least, it not looking good right now.
HS
IN THE UNITED STATES DISTRICT COURT​
FOR THE EASTERN DISTRICT OF KENTUCKY​
AT COVINGTON​
COMAIR, INC., Case No. 99-250​
Plaintiff, Judge Bertelsman
v.
AIR LINE PILOTS
ASSOCIATION, INTERNATIONAL,
Defendant.
PRELIMINARY INJUNCTION​
Upon the reading of the Complaint, the memorandum of law in support of COMAIR Inc.’s motion and affidavits in support of that motion, and upon consideration of the proceedings heretofore had, this Court specifically finds as follows:
That the Defendant Air Line Pilots Association, International ("ALPA") is the collective bargaining representative of the pilots employed by Plaintiff COMAIR, Inc. ("COMAIR").
COMAIR is a common carrier by air subject to the Railway Labor Act, 45 U.S.C. 145 et seq. (the "RLA" to the "ACT").
That there exists a collective bargaining agreement between the parties.
That the parties currently are engaged in collective bargaining for a successor collective agreement, pursuant to Section 6 of the RLA, 45 U.S.C. 156.
The RLA requires the parties to observe the status quo during collective bargaining until and unless the parties exhaust the negotiation, mediation and arbitration mechanisms established by the RLA for the resolution of "major disputes."
Those processes have not been exhausted.
Notwithstanding its statutory duty to maintain the status quo, Defendant ALPA and its members have violated the status quo by the manner and means in which its members have written-up mechanical deficiencies.
Pursuant to Consolidated Rail Corp. v. Railway Labor Executives’ Ass’n., 491 U.S. 299, 303 (1989), "district courts have subject matter jurisdiction to enjoin violation of the status quo pending completion of the required procedures, without the customary showing of irreparable injury." Rather, it is sufficient for the plaintiff to demonstrate that the defendant has violated the status quo prior to the exhaustion of the RLA’s procedures for the resolution of major disputes.
Even if Plaintiff were required to demonstrate that the traditional equitable factors were met prior to the issuance of injunctive relief, that burden has been met, inasmuch as Plaintiff has suffered from irreparable harm, and will continue to suffer irreparable harm, unless an injunction is issued. Moreover, it has demonstrated a likelihood that it will succeed on the merits, and that the public interest will be served by the issuance of injunctive relief. Finally, the balance of hardships tips in its favor, inasmuch as the injunction sought by Plaintiff COMAIR does no more than require Defendant ALPA to comply with the mandates of the RLA.
WHEREFORE, for the reasons set forth herein, and as set forth more fully in Plaintiff’s Complaint, motion, memorandum in support of its motion, and supporting affidavits, Plaintiff is hereby granted a PRELIMINARY INJUNCTION.
IT IS THEREFORE ORDERED that ALPA, and its officers, members, representatives, attorneys and agents, and the airline pilots employed by COMAIR, and all persons acting in concert with, through or under them and each of them, are hereby restrained in the manner set forth below:
From calling, permitting, authorizing, encouraging, participating in, approving of, or continuing any disruption, curtailment, or restriction of normal airline operations or procedures, including but not limited to improper maintenance write-ups, slowdowns, or other work stoppages and all acts in furtherance or in support thereof:
AND IT IS FURTHER ORDERED:
That ALPA, its officers, members, representatives, attorneys and agents take all steps in their power to prevent said disruption of normal airline operations or procedures from continuing, including but not limited to, the following:
instruct all pilots to refrain from improper maintenance write-ups, work slowdowns, or any other disruption of COMAIR’s flight operations, and provide COMAIR a copy of all such instructions.
notify, by the most expeditious means possible, all ALPA-represented pilots employed by COMAIR of the issuance, contents and meaning of this preliminary injunction, and produce a copy of all such messages to COMAIR.
that the notice described in (b) above include a directive from ALPA to all COMAIR pilots to cease and desist upon pain of fine, suspension, or other sanction from improper maintenance write-ups, or any other disruption of flight operations, and to cease and desist all exhortations or communications encouraging the same.
that ALPA post the notice described in (b) above to its Internet web site, and provide a copy of the notice to COMAIR.
that ALPA include the contents of the notice described in (b) in a recorded telephone hotline message to all COMAIR pilots, and provide a copy of the message to COMAIR.
that ALPA report by 1200 noon on December 22, 1999, by sworn affidavit, the methods used to effect the notice described in (b) above, with a copy to COMAIR and the Court.
IT IS FURTHER ORDERED that a bond is hereby set in this matter in the amount of $25, 000 to be deposited with the Clerk of Courts.
SO ORDERED this 21st day of December, 1999, 5:45 p.m. E.S.T.
/s/ William C. Bertelsman
U.S. DISTRICT JUDGE
GAME ON, GAME ON
How long will it take before the injunction happens?
FLOPS is fighting 1108. 1108 is fighting the IBT. You have split support and nothing but turmoil. You wanted a union, you are getting exactly what you asked for. The folks that I pity the most are the non-pilot employees that have no alternative but to live with the antics of the radical union mentality of pilots like you.
And again.. I'm not the one that needs an updated resume. I'm smart enough not to work where there is a union.
You want a definition for FUD???
AT COVINGTON​
v.
AIR LINE PILOTS
Defendant.
U.S. DISTRICT JUDGE
This is FUD
Everyone,
Be professional. Do NOT fly broken airplanes. If it doesn't look like it came off the factory line, it is BROKEN and needs to be written up. Your Owners are paying a great deal to fly on your airplanes and deserve nothing less.
Be professional. Do NOT fly into unsafe weather. Use your gut. If you feel uneasy about it, there is a reason. You aren't doing your Owners any favors by getting them in a dangerous situation.
Be Professional. Do NOT fly hungry. Do you think you are going to be able to react correctly if you are thinking about your rumbling tummy? You are not doing your Owners any favors.
Be professional. Do NOT fly tired. Remember the "I'm Safe" checklist.
Be professional. Do NOT fly sick. If you think you are doing your partner or the Owner a favor you are DEAD wrong.
Be professional.
This is Fear, Uncertainty and Doubt at it's best.
GAME ON, GAME ON
:crying:
Fischman, you needed to highlight this one too if you are going to call the other one FUD. This one is true FUD.
The injunction was FACT. Has 1108 got $25000 hanging around as bond? Have they still got solid backing by IBT? ;)
http://www.airlinesafety.com/articles/ComairInjunction.htm
As Dimeline says..."Game on".
Best time to check all 49 items:
1-Before a passenger leg
2-When aircraft is out of the country. Do a really good pre-flight in Bermuda or the Bahamas, that'll show them.
I'm an outsider but you are a real a$$. I guess you don't want better for your fellow pilots - you sound like a great guy. FLOPS pilots have put up with enough $hit - it amazes me that so many have actually remained.
I hope you guys bring FLOPS to its knees - GOOD LUCK!!!!!!!!!!!!!!!!
:crying:
As a matter of FACT, IBT 1108 does have $25,000. We don't need International for help.
I don't care if it is a FACT or not. Do you want to talk about FACT? The FACT is that you post the injunction here to spread FEAR, UNCERTAINTY, and DOUBT, better known as FUD. Anyone who actually believes you or is frightened by your FUD is a fool.
The message to ALL pilots is as I wrote above.
Be professional at all times. Don't do anything immoral or illegal. Only do actions that will bring honor and pride to yourself, your family, your union, and your company.
B19 is trying to intimidate you. He is a small person (notice I didn't say "man") who should have your pity, not your fear.
All,
Like all good labor battles, the winner will be decided by the court of public opinion. A legal court battle elevates the stakes and public awareness for the eventual PR battle. It's always interesting to read about a company advocating flying millionairs in broken [unsafe] airplanes; compound the awarness with new low(er) time pilots in the cockpit... The press releases are Q'ed up - I am sure.
The definition of "status quo" becomes the legal debate. The company's written position, there is "no status quo" while negotiating the first contract. They have reduced this to writing as their official legal position.
The answer is simple, "NEVER DO ANYTHING ILLEGAL FOR OR AGAINST THE COMPANY."
:bomb:
B19, Please name one of the 50 preflight items listed above that is not a valid write-up.
I didn't say "work slowdown", "job action" or any of the sort. Actually check the age of any of our planes, you will see that they break. That is it nothing more.
Do nothing illegal for or against the company.
Its also funny, company management said they can't afford a "netJets" payraise. Didn't they say right after the vote that there was a 30% payraise on somebodys desk that they were bragging about, but, but you voted in a union so we "Cant give it to you, status que".
I guess we'll have to wait and see how 'split' the support is. The crap this company has/is pulling continues to strengthen the Union support. Just ask our membership chairman - although pilot attrition continues at record pace, Union support is INCREASING!! Heck, even new hires are participating on Union committees.:p
Folks, just IGNORE B19. There simply isn't anything relevant he has to add to this conversation. He has no dog in this fight. He is irrelevant.
Really, if he's ignored, he'll go away. Most normal people get tired of talking only to themselves for any length of time.
As for the mantra "Don't do anything illegal for or against the company", trust me, it works great!! As long as you're legal, there's nothing anyone can do to you.
Ok B19, I've been quiet long enough.
Tell me what I should think when my program manager tells me over the phone regarding dead e-bats the the mx dummies left on all night...and I quote "well as long as they're charging I'd go". Says I "well I know for a fact that the mx manual says that they have to be bench discharged and then trickle charged for at least 18 hours...email me via blackberry and I'll go."
30 min later I have my hotels re-upped.
Same type of scenario 4 other times. Same PM.
So this tool is the SAVIOR of the company and I'm the bad guy? Kiss off you F*&%ing SCAB.
Why don't you go sell your children to a kiddie p0rn ring while you're at it.
Go save Avanit Air or something hero.
SCAB
SCAB
SCAB
SCAB
SCAB
GODSPEED Guys and Gals! Always remember...
...whatever the cost may be, we shall fight on the beaches, we shall fight on the landing grounds, we shall fight in the fields and in the streets, we shall fight in the hills; we shall never surrender! :uzi:
Sir Winston Churchill
Exactly why people like the OP shouldn't be bashing them...
I don't think that Dime Line was bashing the new hires. He like many of us are baffled on how someone would want to even come here with the current environment. He shoud re-phrase the comment to read-You knew it sucked-but you came anyway-F&%k if we will ever know why...so get on board-Pay your dues- and fly the pledge.
Happy Easter..
I like how the company tries to say we are not like NJ, FJ, or CS. They have deeper pockets where the money can come from. Hmmm....wern't we in that exact same boat before. Well the idiots wont talk about the turbo prop frac that don't have the "deep pockets" and they all are paying more than us, lots more. 10 year guy at XO jet is around 132K, Avantair 98K, and the single engine turbo prop frac PlaneSence is also above us at 77k AND A 7 AND 7 SCHEDULE. So when Baboo says he doesn't have the money to pay much more than we are getting now, I say, I don't believe you and that's not our problem. If you can't do it, just shut the doors!
Happy Easter..
Exactly what I mean't. If their not paying, im gonna bash....Game on
I I say, I don't believe you and that's not our problem. If you can't do it, just shut the doors!
I agree shut the doors if you can't pay what the others are paying. Why should FLOPS bring down the wages for other pilots just because they have bad management.
I am sick to death of every fractional thread being hijacked by B19. People pay good money, for good information, and have to wade thru his Sh&t on every post. Flight info do us all a favor and remove this idiot from your website....
T-1,
Most of us have put him on ignore.
He never has anything useful to say -just the same ole drivel -so it just blanks it out. Brilliant!!
I countered an insanely stupid post with fact of what can happen when pilots conduct unsanctioned work actions and you consider that hijacking a thread.
Sad.
Place me on ignore. Nothing would please me more.
Exactly.
It doesn't become illegal until the court order.
Until the court order, it's only stupid, selfish and counterproductive.
Good thing B19 flies a desk and not an airplane. According to him it would be stupid, selfish and counterproductive to thoroughly preflight an airplane. I guess, as a management stooge, he would be happy to fly any old plane into any old situation. B19, keep up the good work. You are a shining example.
I am continuously tempted to put B19 on my ignore list. The drivel is non-stop. I don't know though. Maybe this is my little confession. You know how when you are flipping channels and you pause for just a little while to see what trash is on the stage on Springer. That's how I feel about B19. You just can't help but look. It's like an accident on the highway. Admit it, we all slow down hoping to see a little blood. It's OK. Well, lucky for us, we have our own little highway accident right here on FI. We get to slow down everyday and see what is left on the side of the road. Just another pile of sh!t named B19.
Keep it coming, B19. I personally look forward to seeing that stupid blue font because I know a good laugh is soon to follow.
It's always amazing that the stupid, selfish and counterproductive actions stop as soon as there is either a court order or T/A.
That is what proves they are stupid, selfish and counterproductive. :D
Finally, somebody that understands. :beer:
Whew, I thought it would never happen. It's all about the entertainment value. :laugh:
