FX-3 MAIN volts indication issue
Cactus Charlie
CCX-2000 (FX-3)
KDVT
Commercial ASEL, ASES, AMEL, glider. CFI glider, ASE, Instrument.
My FX-3 shows Volts-1 about 0.6 with IBBS on, Master off, and all breakers in. I have looked at the logs from several other FX-3 and they all show this anomaly but with some variation in the voltage.
This has bugged me for years but I recently took lots of measurements which I think indicate a voltage offset in the ground references provided to the GEA 24. I'm still looking through my measurement data and I have some ideas of what to test next.
One test case on my FX-3 was interesting and I'd like to know if other FX-3 (or EX-3) show the same anomaly -
IBBS On, Master Off - record and report Volts-1 (main bus) and BAT Amps
Pull GEA circuit breaker - record and report Volts-1 (main bus) and BAT Amps
Push GEA circuit breaker - record and report Volts-1 (main bus) and BAT Amps
There's been talk of parasitic drain when a FX-3 is in the hangar and why most have to leave it on a charger unless using an EarthX battery. I wonder if this is related and what may be that drain?
The main battery on an FX-3 has three parasitic loads. My measurements show the currents taken by those loads are:
40 μA - GPS keep alive
115 μA - left ignition module
115 μA - right ignition module
I do not believe these parasitic loads are related to the anomaly in indicated Volts-1.
Can you pull different breakers and try to narrow down where it is coming from? I have not searched the EX-3/FX-3 electrical wiring diagrams, but I would guess there is a pull-up resistor or similar somewhere connected to the wrong bus...
I have data for many different CB pulls but before I share that I want to know what others see. I'm particularly interested in indicated BAT AMPS with GEA CB pulled as that result was quite surprising.
I currently suspect a problem with the ground path of the IBBS but I'll have to insert a breakout connector to get more data.
I have already established that there is a difference in potential between the braid that grounds the transponder chassis and the bracket that mounts the Aux 12 VDC outlet.
Don't forget that GEA, GDU, and GSU breakers only feed power from main bus and should not be passing any current with main bus dead and those LRU powered by IBBS only. IBBS power does not go through any breakers.
If I look at the G3X Touch data log from the first leg of the day on Monday, I see 0.4-0.6 Vdc on the main bus when the main bus switch is off, and the G3X Touch is running from IBBS.
My preflight procedure is to first boot the G3X Touch off the IBBS, do inside checks while waiting for the boot and for ADAHRS to complete the self-test, then power on the Master so I can preflight pitot heat (see current rise), strobes, nav lights, wig/wag, stall horn, and trim. I then turn off the main bus and leave the G3X Touch running off IBBS while I complete the outside walk-around so that the GPS and SXM weather have time to "lock" and refresh their data (If I had the GNC355A on the IBBS, it could also GPS lock, refresh, and I could load flight plans before engine start).
In the logs, I can see it at about 0.5 Vdc before I ever turn master on, and after I turn master off, it drops back to 0.6 Vdc, eventually decreasing to 0.4 Vdc just before I turn master on before engine start.
Anyone?
I flew for a few hours today, and yes, you are correct: it is definitely the GEA breaker back-feeding the main bus from the IBBS. IBBS on, master off, GEA breaker on = 0.5 V, IBBS on, master off, GEA beaker off = 0.0 V. I will need to take a look at the GEA wiring diagram to see if it is something obvious.
That was not my conclusion. I suspect a ground reference issue.
What BAT Amps did you observe with GEA CB pulled? That was the information I wanted most.
I just took a look at the wiring diagrams for the GEA 24 (SK71156 Rev A from the EX-3 dropbox) and the battery connections (SK75101 Rev NC from the EX-3 dropbox), and there are a number of obvious issues:
  • The Main Bus Voltage (VOLT 1) does not work if the GEA breaker is open, as it is connected to the main bus via the GEA breaker. If you look at the Garmin G3X Touch Avionics Installation Manual (190-01115-01 Rev AZ), you will see that VOLT 1 should be connected independently to the main bus via a 1 Amp fuse. This explains why the voltage goes to zero when the breaker is open. This probably needs fixing when I get my hands on the necessary tools.
  • The main battery shunt is installed between the master contactor and the main bus. As there are a number of loads (e.g. both electronic ignition modules - 2 * 1.3 Amps, the contactor coil > 0.6 Amps, the 12V accessory power plug, external battery charger, etc.) connected to the input of the master contactor or directly to the battery contacts, these are not visible by the GEA 24 shunt. Last week, when I was looking into the actual power consumption vs book typical power consumption, I did not attempt to use the shunt but rather used an external current clamp around the main battery ground wire (e.g. the G3X Touch often shows 2-3 Amps when the battery is fully charged as this is the power consumed by the electronic ignition and the master contactor coil). The GEA 24 connections for the shunt are reversed from the Garmin documentation, but as the GEA is just reading the differential voltage across the shunt, not the absolute voltages, this only reverses the sign to make the number look like a "charging current" rather than a "battery current".
I need to think more about the other changes they have made from the Garmin examples to see if I can spot any other issues. And as far as the actual main bus voltages and currents, I think that I will need to connect up an external multimeter instead of trying to use the G3X Touch / GEA 24...
I agree with those observation but they do not explain the full set of measurements that I made. I measured MAIN bus volts with an independent meter.
Still hoping for someone to run the test I specified.
I did a lot of experimenting to understand how the IFR GPS and G3X Touch systems interacted. I included everything I learned in my AFM avionics supplement. One note says -
"Note - An internal flight plan may be created in the G3X system while running on IBBS before engine start. Save this flight plan before engine start to avoid accidental loss. The flight plan may be transferred to GPS 175 after engine start and avionics bus activation."
Have you ever actually observed this?
The IBBS should enable power to the GDU backup power pins before the main battery gets low enough to cause a GDU reboot (it is a race condition as far as I can tell). If this is not happening fast enough, we may need to connect the IBBS power input pins such that the IBBS output pins remain active at all times.
Yes, that's why I put the note in my AFM supplement.
It has nothing to do with GDU power. In my case it was caused by an incorrect sequence that resulted in the GPS 175 null flight plan replacing the GDU flight plan.
If the flight plan is complex then saving it before powering the IFR GPS can save some aggravation. Best to get that done before engine start.
0.2 -1
0.0 -1
0.2 -1
0.2 -1
0.0 -1
0.2 -1
Interesting, thanks.
Your FX-3 does not behave like mine for this test. Your Main bus volts is much lower and there is no change in indicated battery current. Perhaps CC changed something in the grounding. Yours is several years later than mine and has the factory IFR fit.
My results:
0.6, 0
0.0, -3
0.6, 0
Some more really easy measurements today. Using battery negative terminal post as the reference I measured the voltage at 3 points under various test conditions.
The test points were:
1. Aux power bracket
2. Braid strap that links fuselage V tube ground lug to transponder chassis
3. Braid that links engine to engine mount frame
Test conditions were:
a. IBBS On with GEA CB In
b. IBBS On with GEA CB pulled
c. IBBS Off
All test points were 0.0 V with IBBS Off.
With IBBS On the results for all test points were the same whether GEA CB was In or Pulled. Those results were -
Aux bracket -0.2 V
Tray braid +0.6 V
Engine braid 0.0 V
Next step will be inspection of voltage at the frame V tube ground lugs and the quality of the connections between the lugs and the various attached ground leads. The problem could be as simple as failure to remove the powder coat from the lugs.
Today, I noticed that the stall warning horn was working softly with just IBBS enabled after the plane had been completely off for a couple of hours, and the master had never been turned on. I had never tested the stall warning without the master on, as I had assumed it would not work.
I now need to test the stall warning horn with IBBS on and the GEA breaker pulled to confirm that is where the power is "leaking" next time I am out at the plane.
The reason the stall warning horn sounds in this situation is that the IBBS has a large capacitor on the charge voltage input. It back feeds to MAIN bus.
It doesn't need IBBS to be on.
Pull the IBBS charge CB and the horn will not sound.
Tested and confirmed with TCW a few years ago.
That was true in Jan 2021 when I ran the test and communicated with TCW.
Today I ran the same test again and the stall warning did not sound. I ran the test several times before and after flight and the earlier test result could not be reproduced.
I then realized that, since Jan 2021, I have exchanged my rev G IBBS with a newer rev J IBBS. I suppose it is possible that a diode was added to prevent the capacitor back feeding to the charge input.
To add to the mental re-calibration I found that IBBS On and GEA CB pulled did allow the stall warning to sound very weakly. It would not sound with GEA CB In.
I heard the stall warning a couple of days ago when bumped the vane while cleaning bugs off the leading edges after a flight. Master off, IBBS off, and all CB normal.
I bench tested a spare IBBS and found the charge input pin holds 1.75 V long after the charge input has been removed.
