gunfyter
- Mar 25, 2002
There is no problem with the pay. Because of the change... 40 hrs from 2007 will be paid in the first check in 2008.
This might make Options books look better for 2007.
To make you feel better they could add another payday on the last Friday in December for just 40 hrs. Then shift the NEXT payday friday from Jan 4 2008 to Jan 11, 2008.
This is Probably what they should do... because many people don't understand there is no real change in pay.
Grump is right. If they had started the new system in january... no one would be confused.
		 Could it be that we all share more common ground than you think....
 Could it be that we all share more common ground than you think.... Thicker skin? Been there, done that. It does help. I hope this finds you and yours well, RNO.
 Thicker skin? Been there, done that. It does help. I hope this finds you and yours well, RNO. Hence, the reason for RNO's frustration. Our own NJAOwner has made it clear that he is pleased with the value received.
 Hence, the reason for RNO's frustration. Our own NJAOwner has made it clear that he is pleased with the value received.  "Owner, my regards to you and your family. It is always gratifying to read your friendly expressions of appreciation and concern for the flight crews. Thanks for your patronage!
