Flight department staffing
ILOVEBEER
Total Time
8
What would you consider "adequate" staffing for a part 91 flight department with 3 airplanes? Each airplane flies between 250-400 hours a year. There are the occasional trips to europe, but most of the flying is domestic transcons.
K.V.
Total Time
a lot
9 minimum, 10 - 12 would work better, especially if your flying transcontinentally. You could also form a pretty decent schedule with that staffing ratio. Now, getting the principals to sign off on that is another battle.
semperfido
Keep Humpin
Total Time
11K+
for past 25 yrs the depts I have been affiliated with always had ten for three acft. seems to work fairly well
ILOVEBEER
Total Time
8
Thanks for the input guys and I am familiar with the rhetoric on Flight Info, like 'don't do anything my flight department wouldn't do', so give me a real world number. We rarely use contract guys and we seem to fair pretty well on far fewer guys, however, I do feel we are understaffed. So forget the "in a perfect world" numbers and tell me what is an acceptable number. In an AVERAGE world and if the job is a really good job, what is the minimum staffing level for a 3 aircraft flight department where you would accecpt a job?
All three aircraft are the same type and there are no SIC's. All PIC's
sleepy
Living The Dream!
Total Time
8,500
4.5 pilots per aircraft if you want to average 15 flight days per month plus be able to cover vacation and training.
FO4life
Total Time
4000
If all three aircaft are flying you want three per aircraft. what do you do more sit around or fly. if only one or two fly at a time then two per aircraft. here is the thing you need to cover the plane with some one on vacation and some one sick, or at school. If you can't cover the schedule with two guys out, you don't have enough.
Fly91
Registered Pilot
Total Time
lots
At least have all qualified PIC's, there's no reason to have SIC's, that can only put you in a spot. 9 is all you need for 3 planes to have a good schedule and coverage.
MaxTorque
Total Time
7K
staffing
I'll add that it also depends on what else you have going on in the department. Do you train once or twice a year? How often do you do other training - jet upset, water survival, attend CASS/Safety Standdown, NBAA, etc. Another factor could be compensation; what if your company's culture won't support a salary that keeps guys running hard year round happy but doesn't blink about another pilot? That investment in another pilot not only adds scheduling flexibility but maybe reduces turnover.
Just don't get sucked into a minimal staffing model then start adding things like ISBAO certification and chasing "world class" status without realizing the implications. Boiled frog happens more often than you think.
MT
ultrarunner
Total Time
10000
NBAA has some good resources on it's website that deal with pilot staffing.
The number of hours flown per year is only part of the equation. MUCH more information needs to be evaluated....
Start looking at time-away-from-base first vs. hours flown.
You really need to sit down and also carefully evaluate your companies policies:
1. will you train once or twice a year.
2. when you do train, will be be as a crew or individually.
3. How much vacation time do you need to budget.
3. How many guaranteed days off, if any, per month need to be bugeted.
And a big question is, does the corporation WANT all 3 aircraft to be able to be dispatched all the time. Issues such as these will dictate where you need to start with your staffing models.
Catfsh
Member
Total Time
6000+
8
All three aircraft are the same type and there are no SIC's. All PIC's[/quote]
jws717
registered abuser
Total Time
loads
So it sounds like you need some new pilots. Can you hook a flight info brother up.
Stryker
Active member
Total Time
3
9 Captains will work out to be, between 12 and 16 days on a month on average, thats covering 4 weeks of vacation a year per pilot and training every 6 months. This is for 3 planes Based on 350 - 450 flight hours a year each
