Fed Ex Feb 21st class
  • Thread starter Thread starter Reddie
  • Watchers Watchers 20
fdxhopeful said:
Anyone know how they'll choose who goes where? Will we have a choice based on seniority, assign based on seniority, or dart board method?
USNFDX is correct.
When I was hired back in '01 there were 24 in each class, 8 went to the back of the 10 and the other 16 to the 27. Your class will be put in seniority order based on the last 4 digits of your SS#, highest to lowest.
I got the 11th pick and thought I might have a shot at the -10 but unfortunately the first 8 all choose the -10 and everyone else got the 27.
Good luck and welcome aboard.
FedEx1 said:
Hey works for me, bring on the pass over pay while I wait until my MD-11 class.....
FedEx1,
Not sure what seat you're in now, but you only get that passover pay if a junior guy goes to a seat you have a standing bid on before you do. If you have a bid for the MD-11 and a junior guy goes to the 727FO seat, you don't get any passover pay. If you did have a bid for the 727FO seat and changed to the MD-11 FO seat on this last bid before going to your boeing training, you will have to pay it back since you never completed 727FO training. Of course, I've been proven wrong on the passover pay issue before, I could be wrong again.
BIGBROWNDC8 said:
Dave Siegel,
PS... Imagine a flight where you get direct anywhere you go and there is absolutley no radio traffic. No sun rays to give you skin cancer. Nasty WX caused by heat thermals, nope dont have those either... Its not all that bad...
I concur on the directs and the WX. However I poked around on APA website and found this info on the radiation hazards:
"Ultraviolet (UV) radiation, which is the kind of radiation you wear sunscreen to protect your skin from, is non-ionizing radiation (it does not penetrate beyond the surface of the skin), nor is it an in-flight exposure issue since commercial jet aircraft windshields manufactured since the 1950’s screen out practically all UV rays. Although this was originally done to protect the aircraft instruments, it also means that you can skip the wearing of sunblock on the flight deck."
And this. Note how altitude effect exposure:
Understanding The Variables Affecting In-Flight Exposure
Cosmic radiation is scattered around to both the sunny and dark sides of the Earth, so day versus night flying does not appreciably change how much cosmic radiation you receive during flight. The amount of radiation that anyone—passenger or crew—traveling in an aircraft receives, is a factor of:
Aircraft altitude: Radiation levels double with each approximate 6,500-foot climb.
So doing some math calculations, the atmospheric cosmic radiation at FL390 is about 64 times greater than at sea level. At FL 330, the radiation level is significantly lower at about 35 times more than sea level amounts. Therefore, if climbing to the next flight level doesn’t save you fuel, time, provide a much better ride, or some other important operational consideration, then think twice about it.
Aircraft latitude: As an aircraft flies closer to the poles, occupants are exposed to greater amounts of radiation. At latitude 70º N, cosmic radiation levels can be as much as four times higher than at 25º N, at any given altitude. Aircrews who regularly fly from North America to Europe and Asia routinely receive the highest exposures to in-flight cosmic radiation, which can be as high as 6 mSv or more per year depending on the combinations of the other variables. (NOTE: 1 mSv or millisevert is recommended exposure for the general public -- Unit)
Length of time at altitude: Long flights at cruise altitude expose crews to more inflight radiation versus short hops.
(Due to this my International days are over although Deep South is probably better -- Unit)
Period during the 11-year solar cycle: The Sun follows a high to low then back to high level of flare activity which runs in an approximately 11-year pattern. When the Sun is in its’ more active phase, less galactic radiation conversely reaches our planet.
Solar flares: These events are sporadic, and can vary greatly in strength and degree of biological concern, boosting in-flight exposure levels by 10 times or more. Elevations in radiation levels that are induced by solar flares can last for a few minutes or a few days.
This probably deseves its own thread. The whole article is 9 pages long.
Unit
I'm on the -10 panel, at 5 numbers from the bottom.
I can't even hold reserve. The last ~8 of us get VTO lines. That means reserve, but no control over the dates and you don't find out your schedule until the Wednesday before the month starts. (If preferential bidding is so great, why is VTO on the bottom?)
I'm heading to the MD11 in June. The -10 is a nice ride, but the top half of the list is over sixty. Until they all go back to the left seat when the rule changes....
How long would it take to go from the right seat of the 727 to the right seat of the MD.And do people usually wait for the MD or due they go to the Bus?
very quickly
With the big bid and tons of hiring, movement is very fast right now. Guys in new hire class were getting the MD-11. They will still continue to finish 727 panel class, but later in the year, they will return for MD-11 upgrade.
The Airbus is more senior than the MD-11 for now.
Goose17
Yeah I guess no passover pay for me. I actually got out the contract, could find the right section, read it and understood it without called a lawyer. It was a miracle. Now I have a new found confidence in my abilities and I didn't even have to stay at the Holiday Inn Express last night.....
Hi
Heard from a friend that was down for the met and greet that FDX is really churning up the hiring for March and April. It's been 3 weeks for me and no news yet. Good luck to all.sean
Passover Pay. . .
active_herk said:
FedEx1,
I got a couple weeks of passover pay last year and this is how it worked. . .
The passover people (Crew Pay, I think) wait until both you AND your junior dude activate before they dole out the passover pay in one lump sum. That keeps them from any possibility of having to collect it back if either of you don't complete training.
Once the training letter is out, they will identify the person that is junior to you that will activate passover pay. They say that they scrub the list continually, but I found it doesn't hurt to make a reminder e-mail or phone call after you activate to ensure they didn't "forget".
sean67 said:
Hi
Don't want to jinx ya but if you haven't heard anything in 3 weeks then that is GREAT news. If they don't like you then you find out pretty quick. From what I understand though they won't call you for a class date until all your paperwork checks out which for some takes longer than others.
Have you called KD to check your status? Wouldn't be the first time some paperwork got miss placed. Just a thought.
Also what is the difference between the the DC-10,MD-10
your job, can't stand people who get the opportunity at such a great company and don't even know about their equipment
HH
How long can a new hire direct to B727 FO plan to sit reserve?
How long can a new hire B727 FE plan to be on reserve?
Thanks.
Thanks.
I'd say that a new FE should be off reserve in under 3 months (assuming hiring continues as forecast).
As for the new hire FO -- anybody's guess, but I'll venture at least 6 mos to a year.
727 FO reserve
There really isn't such a thing right now. I finished upgrade training in Nov. I got a custom line in Dec. Jan I got reserve which was voluntarily converted to a secondary line. Feb I held a line.
I was dead last on the right seat seniority list and never sat reserve. I am probably still in the bottom 30 and no sight of reserve. We are SO SHORT in our seat there really isn't anyone on reserve. Coverage of sick calls and last minute added flights are all covered by draft/volunteer.
Our "max open" (amount of reserves for any give day) is usually around 3-5 per day. This is reserve-24hr, reserve-B, and reserve-A all together. Like I said, no-one is on reserve.
Goose17
72 FO new hire time in seat
Great info all, much thanks!
Here's a question for anyone: if a new hire goes right to the 72 FO slot, is he/she locked into that seat for a minimum time period or can they bid right seat of the Maddog (should that be available to them) in the next vacancy bid (which a lot of folks are saying could be within the next year)?
as long as it is upward movement, you can go anytime, lateral or downward movement is a 2 year freeze...
also heard today that in march there will be 2 classes of 58 each!!
anybody know anything about this?
Los1
Heard the rumor too!
A buddy of mine just interviewed today and he was told the same in regards to two classes of 58 in March ( for a total of 116 .... I ran out of fingers and toes so had to break out the calculator). Seems that was all the interviewers spoke of today during the informal "lunch interview".
Where'd it go?
Right in the lumberyard.
Don't worry Danny,....the world needs ditchdiggers too.
Pick Up the flag!! No Infraction on the field!!
Touchdown T.O. and the Eagles win the Super Bowl!!!...
Oh wrong fantasy, S#it the Eagles still lost (we WILL be back!!)
Anyway-
just spoke again to my bud who interviewed yesterday and the day before (8 and 9 Feb).
Straight from John Ryder--
two classesof 30 in Feb (21 and 28 feb)
2 Classes of 58, I say again 58, on 21 and 28 Mar
pretty friggin' amazing
see ya
Los1
E-A-G-L-E-S--Eagles!!!
Next bid
After our last large bid, I wouldn't expect another bid until late fall. HOWEVER, after reviewing the training letter, the last guys to start 727 FO upgrade enter class on Jun 22nd. That said, I would imagine there would be another bid early summer to keep the pipeline going.
Hiring directly into the right seat could slightly change the theory.
Goose17
