seethru
Works for a Living
- Apr 15, 2004
This question revolves around the thrust reverser(s) on a Falcon 900.
First, I have zero experience with any of this equipment, so maybe this is a simple question.
From what I have observed in other aircraft with thrust reversers there is a second, smaller set of levers on top of or forward of the thrust levers. Basically, one for each lever. I think I am correct in assuming these are the levers that are used to produce reverse thrust.
However, I was in the cockpit of a Falcon 900 today and saw that there was only one of these smaller thrust reverse levers, and that it was for the middle engine.
Am I to assume that there is only one engine on the 900 that produces reverse thrust?
I don't know why I need to know this. It's just one of those things that will keep me up tonight going Hmmmm.
Thanks and clear skies.
