not if you're hauling boxes part 135.
Yeah I was gonna say...I've done quite a few flights in the caravan with no tcas. In fact, 1200 hours worth.
I think it might have to do with passenger carrying and/or number of seats.
WalterSobchak;1578551 While said:walter - read my above post. your right a mel'd/defered tcas is perfectly legal however legal doesn't alway mean safe. the ca of that flight had valid reasons to cx the flight.
INOP TCAS will ground an airplane?
That' what I don't get.
I know you need it for RVSM airspace.
I guess looking out the window doesn't count anymore.
Ok I get... they fly in the south where there is a lot of solid IFR condition.
according to the artical {sic} the tcas was fixed and signed off by a mechanic in TPA....therfore there was no reason to refuse it on that basis.
While the plane was parked in Tampa, a mechanic found the system was operating properly. Edwards, however, didn't think it was and insisted he could not conduct the flight.
The Mel's serve a purpose and they are approved by the FAA...it's it's legal and safe to go with it mel'd then that's what you are expexted to do....
But if the guy who signs your paycheck says to you that you have a choice: fly it or be fired. I can guarantee you that Tom Herfort would NEVER say that if it were NOT legal.
I agree with you almost completely (especially with that last partFor how much FI likes to throw guys under the bus I can't beleive this is what pilots are supporting.
First of all if it is properly MEL'ed and deferred the captain has very little ground to refuse a flight. You can use the multiple MEL's make it unsafe arguement here but it is pressing it.
Second, all the 1900's I have flown have TCAS I only.. no RA's. In fact FOM at the last place specifically said do not climb or descend in response to a TCAS advisory as it may be incorrect(and often was).
Oh.. TCAS definitely can be deferred on 121 turbine passenger carrying ops.. depends on the plane, but some can do it.
Finally I'm pretty sure on the ground authority is jointly shared by the captain and dispatcher, only after leaving the gate is the captain "the final authority"
Sounds like this guy had a beef and pressed his luck..
