Spinplate
- Jul 7, 2005
pilot1704 said:I think only way to do it is with autopilot!
Done that and it worked well! We had smoke in the cockpit, so we were unable to see aircrafts attitude , speed, etc.... We got masks on, pulled paxs masks out. We cranked altitude alerter to zero, then went up 10 clicks, worked for that location up to 10000ft. With autopilot on,command nose down, in our ac hold wheel 10 seconds and should give 10degrees nose down I also pressed heading putton and turned little bit to the left away from airway. We pulled power idle, speedbrakes out, notified controller, finished rest of the memory items, at that point we started to see something, we were through 17000ft. And biggest hurry was behind us.
If we would have disconnect autopilot I dont know what would have happend. Maybe unusual attitude, structural damage, stall, CFIT... that is scary tought.
So I stick with autopilot!
In that situation yes of course, you would NEED the A/P, it is completely situational as when you should or shouldnt use the A/P in an emergency descent.
