DL 757 engine smoke in EGE???
Those engines smoke a lot when started in the cold and high altitude. The RB211's are worse but the PW2037's will still make the ramp IFR.
TC
The RB211 almost killed Lockheed and the L-1011 program.....
Shoulda gone with P&W Power
When? I was there yesterday....
Pretty nippy up there... cold enough for us to use the cold weather approach plates and adjust the altitudes on departure.
Out of curiosity, do you other carriers do that? ATC seems to go cross eyed when we tell them our min altitude for temperature is higher than the published...
Tri-jet History
For those interested in the L-1011/DC-10 and GE/Rolls/P&W competition, a good book is The Sporty Game by John Newhouse.
Cold WX TEMP Adjst.
We do not have another set of chats, we just have altitude adjustment tables for Cold weather and Hot weather ops...
Cold weather adjustments are made for any TEMP below 0C.
Some ATC facilities in regions we operate into already incoperate the TEMP adjustment to the assigned ALT... However, minimas and MDAs have to be adjusted by us with referance to the tables mentioned.
T
What is the reason for the increased cold temp ALT?
It seems that the aircraft would perform better (more lift/power) in colder wx, but I guess that the high altitude could negate that advantage......
You are SO cool. Man, I wish I could be a big 757 pilot like you.
Enjoy your MD back to the M88.
Someone add something to your cheerios this morning?
Uncompensated barometric altimeters can have pretty big errors when the temp get's very cold... We run changes on the required altitudes (either pre calculated "cold plates" or run altitude corrections on the fixes vs. station temp to correct for the errors.
The whole idea is to ensure terrain separation (we only do this stuff in terrain critical airports for the most part). When station temps get below -25C, the whole show comes to a stop and it's day VFR ops only.
