'different' clearances
GravityHater
The more I hear, the better prepared I will be for such clearances - post ones you've heard.
"at ABC 3.5 dme, turn right heading 150 and descend to 2000"
"cleared direct 37dme XYZ 334 degree radial"
"Hold on a sec while I look for your clearance" is one of my favorites. Hence when it's LVFR, I get a void time each time since the FSS can't seem to remeber to make it an IFR plan instead of VFR.
"I've got a revised routing, advise ready to copy" is my favorite.
"upon reaching FLXXX, cleared to XXX"
"Uh wha, you can't cancel now! Stay IFR and cancel on the next guy."
Heard the above today.
Fly SAFE!
Jedi Nein
Heard either JAX or ATL advise Citrus "I have a reroute, advise when ready to copy" and then she went right into the reroute without giving Citrus the option of saying they were ready.
minitour said:
App: Cleared for the left base, contact the tower
Me: Uhhh
App: Have a good night.
-mini
That's always the best, when it's 2am, you check in 40 miles out, and approach says, "Cleared to land 17L, and taxi to parking. Have a good night."
Turn left heading 360, do you have the airport in sight? Yes. Cleared visual 27L (at Ohare).
This is at 4000' and 1 mile from Willt. Hellllloooooo
In-and-out of the clouds descending through about 4,000 on a practice approach, the center controller (who was VERY busy) sez, " Sqawk 1200, maintain VFR, and contact the tower." I politely suggested that even though this was only a practice approach, we were IFR AND IMC and needed an approach.
We were on the las vegas hoover 2 departure, and had just gotten switched to the departure controller:
Dept: "Baron XXX, cleared direct cowboy intersection"
Me: "Uhh, we're a slant alpha, we can't do that, can we get a heading?"
Dept: "Yeah, ok, I lost your strip, I was just taking a stab in the dark"
Makes you wonder...
~wheelsup
So you admitted to breaking the regs on the radio (i.e. flying VFR in IFR conditions?). Do you want to get your ticket yanked?
He mentioned that he was IFR. Plenty of people practice approaches while IFR.
You dont practice an approach when IMC.... you shoot an approach.
As far as ATC losing a strip... its the same as you screwing up a freq change. Get over it and get used to it.
You sure about that?
4-3-21
a. "...Practice instrument approaches are considered to be instrument approaches made by either a VFR aircraft not on an IFR flight plan or an aircraft on an IFR flight plan."
-mini
Flew my 200 up to White Plains from Houston. Received 8 (counted them after we landed) re-routes. 5 hours and 15 miuntes later. We were wonderig if the controlers in the northeast were trying to tell us...No turbine sububans up here.
Ha
4-3-21
-mini
Don't confuse IMC with IFR.
minitour said:
4-3-21
-mini
What i THINK he was trying to say is that when your in IMC and doing a "practice" approach it would be considered a real approach since you in IMC rather then being on and IFR flight plan and doing a practice approach in VMC.
oops...should've quoted Vik also...
He stated he was IFR in IMC...could still be a "practice" approach.......according to the AIM.
-mini
*edit*
Yep...that's what I really meant, but the more I read it (which is bad), the AIM makes no mention of conditions. Only "IFR" (flight plan).
Hey guys, this IS a change item!
This problem is arising from the fact that it used to be that when you were cleared for a "Practice Approach" implicit within that clearance was a requirement that the approach be conducted entirely in VFR conditions. some of us here remember when this was the case.
AIM 4-3-21 lays it all out a bit differently now. Practice approaches are now in the "adjective(practice)/noun(approach)" category as opposed to the "verb" category that they used to be. That is, when you conduct a practice approach, you're practicing your approaches.
FAA Order 7110.65P - the current version of the controllers' handbook is also quite clear and spells out a few other things that the AIM isn't a clear about.
FAAO 7110.65P said:
4-8-11. PRACTICE APPROACHES
Except for military aircraft operating at military airfields, ensure that neither VFR nor IFR practice approaches disrupt the flow of other arriving and departing IFR or VFR aircraft. Authorize, withdraw authorization, or refuse to authorize practice approaches as traffic conditions require. Normally, approaches in progress should not be terminated.
NOTE-
The priority afforded other aircraft over practice instrument approaches is not intended to be so rigidly applied that it causes grossly inefficient application of services.
a. Separation.
1. IFR aircraft practicing instrument approaches shall be afforded standard separation in accordance with Chapter 3, Chapter 4,
Chapter 5, Chapter 6, and Chapter 7 minima until:
(a) The aircraft lands, and the flight is terminated, or
(b) The pilot cancels the flight plan.
2. Where procedures require application of IFR separation to VFR aircraft practicing instrument approaches, standard IFR separation in accordance with Chapter 3, Chapter 4, Chapter 5, Chapter 6, and Chapter 7 shall be provided. Controller responsibility for separation begins at the point where the approach clearance becomes effective. Except for heavy aircraft/B757, 500 feet vertical separation may be applied between VFR aircraft and between a VFR and an IFR aircraft.
REFERENCE-
FAAO 7210.3, Practice Instrument Approaches, Para 6-4-4.
FAAO 7210.3, Practice Instrument Approaches, Para 10-4-5.
3. Where separation services are not provided to VFR aircraft practicing instrument approaches, the controller shall;
(a) Instruct the pilot to maintain VFR.
(b) Advise the pilot that separation services are not provided.
PHRASEOLOGY-
"(Aircraft identification) MAINTAIN VFR, PRACTICE APPROACH APPROVED, NO SEPARATION SERVICES PROVIDED."
(c) Provide traffic information or advise the pilot to contact the appropriate facility.
4. If an altitude is assigned, including at or above/below altitudes, the altitude specified must meet MVA, minimum safe altitude, or minimum IFR altitude criteria.
REFERENCE-
FAAO 7110.65, Altitude Assignments, Para 7-7-5.
5. All VFR aircraft shall be instructed to maintain VFR on initial contact or as soon as possible thereafter.
NOTE-
This advisory is intended to remind the pilot that even though ATC is providing IFR-type instructions, the pilot is responsible for compliance with the applicable parts of the CFR governing VFR flight.
b. Missed Approaches.
1. Unless alternate instructions have been issued, IFR aircraft are automatically authorized to execute the missed approach depicted for the instrument approach being flown.
REFERENCE-
FAAO 7110.65, Missed Approach, Para 4-8-9.
2. VFR aircraft are not automatically authorized to execute the missed approach procedure. This authorization must be specifically requested by the pilot and approved by the controller. When a missed approach has been approved, separation shall be provided throughout the missed approach.
REFERENCE-
FAAO 7110.65, Visual Separation, Para 7-2-1.
As I see it, if you're VFR the controller is supposed to tell you to stay that way and further, they are supposed to tell you that standard IFR separation will not be provided. VFR aircraft are also not automatically granted clearance to execute the missed approach. An additional clearance must be obtained for that.
The bottom line is that this DOES represent a change for us older guys. The term "practice approach," as I said before, used to be a verb and now that term is FAR more literal with far LESS implied meaning.
TIS
Admit we were breaking regs? Who said anything about VFR? I said 'IFR' AND 'IMC'. Read before you speak, man. Jeez.
RJPilott said:
You don't practice an approach when IMC
Folks practice approaches in IMC all the time. Don't know what the heck you're talking about.
Just because I'm on an IFR clearance, operating in IMC, doesn't mean I can't be practicing. The best practice is in actual conditions. I put 'practice approaches' in the comments section of the flight plan, but never referred to any 'practice approach' on the radio. Jeez, again.
Perhaps but it didn't used to be that way. See my post above. There HAS been a change.
TIS
No, I'm not talking about 'practice approaches' in VMC, or even asking center for a 'practice approach.' I'm talking about filing and IFR flight plan, getting an IFR clearance, taking off into the clouds, and getting some practice.
I know what you guys are talking about, but that's not what I mean when I say, "Hey, Bob, I'm gonna' go practice a few approaches in the Baron." I mean I'm going to go fly in the clouds and hone my skills.
How about getting cleared to an altitude that's a few thousand feet below the terrain? I've had it happen twice in the past 2 years. Both times I was single pilot in the soup over big rocks.
Coming from the east coast recently, Center comes on and makes the dreaded statement "Got a new clearance, advise when ready to copy." Scramble for the pen, find a notepad, and she gives us an ungodly long clearance which included no less then three VOR's, three or four airways, and a new arrival into our destination which began at an odd intersection. Of course we immediately requested if we could just go direct to the arrival or destination instead - which she immediately denied with a rather cranky tone about how everyone has to fly in this way, blah blah blah.
So the next few minutes were spent pulling out all our enroute charts, thumbing thru them to find the two we needed (of course its never on just one chart), looked up the VOR identifiers in the Accukwik, pulled out the new arrival from another binder, then dilligently entered them into the FMS.
Took us a couple minutes or so to get it all in the FMS, thanks to it trying to reject the Arrival based on the intersection given.
And I kid you not, no sooner did we hit the ENTER button to add the new routing to the box, as if on cue, the controller came on and said "Cleared direct to destination."
The words that were spoken in that cockpit those next few moments could've made Andrew Dice Clay blush! I was laughing so hard at the Captains non-stop tirade towards the woman controller, that I couldn't even respond back to her with the instructions!
