Diarrhea in the Regionals ?
  • Thread starter Thread starter taters
  • Watchers Watchers 9
taters
This thread has been going for years in the cargo forum..Just thought it would be funny to hear some stories from the regional side.
True Story from spring of 03
A buddy of mine at STL watched two absent minded rampers hookup an airstart bottle to a TSA ATR -42. The problem is the ATR doesnt have an airstart. I believe the A/C was out of service for over two weeks. The F/A quit and some passenger even threatened to sue after turds, poo-poo, crap, feces, doo-doo, , piss, used condoms, tampons, vomitt, excrement, brown juice and $hit literaly blew the lav off of its attachment in the cabin as a result of 1000 psi infiltrating the thunder pot.
A buddy of mine at STL watched two absent minded rampers hookup an airstart to a TSA ATR -42. The problem is the ATR doesnt have an airstart. I believe the A/C was out of Service for over two weeks. The F/A quit and some passenger even threatened to sue after turds, poo-poo, crap, feces, doo-doo, , piss, used condoms, tampons, vomitt, excrement, brown juice and $hit literaly blew the lav off of its attachment in the cabin as a result of 3000 psi infiltrating the thunder pot.
You'd think they would make the lav hookup a different size than the air start hookup so this couldn't happen
That is the exact same story that goes around here at XJT, except just change the plane to Brasilia and the location to Houston.
I stand corrected...the bottles we had at CHQ were 1000 so thats probaly what it was...dont know where I got that thanks for the heads up,,
FlyBarneyJets said:
Show me an air-cart that puts out 3000 psi.
I was thinking the same thing... In the G-V, we need 40 PSI to start the Rolls-Royces up... I don't think there is a huffer cart out there that puts out anywhere near 3,000 psi...
Or 1,000 psi for that matter. Most I've ever seen a huffer cart put out is 65psi. A bottle might give you 50psi if you're lucky and it's allowed to get a full charge.
The bottles with a Diesel Engine hold up to 1000 psi with adjustable output (opening the valve all the way would probably blow the air starter turbine to hell)..Huffer carts dont store compressed air, there just basically an apu on a cart...
O-Line said:
A long time ago, we were flying these Penthouse Pets up to Las Vegas for its 20th anniversary or something in a King Air 200. Well about 2 hours out my partner is starting to get all sweaty, I ask “are you all right”, and he goes “man, that taco shack’s not sitting very well.” I said "well we’re about 2 hours out so you better do what you have to do."
So he goes ‘back, tries to be all suave about it, asks the ladies if they need a drink, etc. Then closes the door and let the hounds of hell lose! This is about the time I go on O2, since my eyes are watering. Anyway about an hour later he does the "walk of shame" and comes back up. As he gets in his seat, I notice his socks are missing. “What happened to your socks”, “man, those b!tches used up all the TP!”
he he
I was on the ATR from 1999-2005 at TSA. That never happened.
The rumor was it was an EMB in Chicago for United.
Since when does a story have to be true to be good?
This is why this thread can't last in the regionals forum...
too many uptight asses trying to prove him wrong or dissect the story piece by piece until nothing is left.
Leave the humor to the freight-dog's section, they still have some in their lives.
Apparently submarines have poop problems also.
It was less than a month before our boat was set to deploy.
Our sea/shore rotation was insane, and so, any time we were in port the CO tried to cut everyone loose. However, it also meant our in-port watchstanding was a little rusty.
When we took the duty, we quickly realized that the duty section we had just relieved had left us with nearly full sanitary tanks. Apparently, they just didn’t want to bother with getting rid of the stuff.
My Duty Chief (our A-Gang LPO) and I quickly realized that we would have to secure the heads until the sanitary tanks were emptied. Therefore, getting the tanks done was a priority.
So, to expedite things, my section leader and duty chief requested that we blow tanks instead of pump them. We normally pumped in port, because it was easier, but, we had blown sans in port before, and, frankly, we wanted our heads back, so I gave the go-ahead.
Now, in Groton, the san tanks are connected by hose to base sewage piping that runs underneath the piers. Spaced along that piping are relief valves, to prevent any gas accumulation from overpressurizing the pipes and bursting them.
However, if you shoot pressurized waste into this sewage system at a sufficiently high pressure, sewage will reach the relief valves and cause them to lift open. One can tell this is happening when the manhole over the lifting relief valve is lifted 6-8 feet in the air by a geyser of poop.
I know this, because, in his haste to empty our tanks, our intrepid on-coming belowdecks watch had, instead of slowly throttling air to the san tanks to blow them dry, and thrown the air valve full open, immediately pressurizing the san tanks to a much higher pressure than the sewage system could handle. In his defense, the operating procedure did indeed say to throttle the air “at sea” to 5 psi over sea pressure, to reduce noise, and didn’t say a thing about throttling in port. However, that did not make the environmental office any happier, nor most of my duty section, which had to assist in the cleanup.
There's more where that came from.
