CLARKGRSWOLD
- Sep 28, 2007
- If you are 200 miles out @ 310, ATC wants 110 @ 40 DME, when do you descent ( I WAS THINKING 80 MILES BEFORE THE 40 DME, ANY INSIGHT ? )
- At 2000 feet on localizer, 5 miles back, where do you expect glideslope to be (This one is confusing 5 miles back from where ? Typical 3:1 here however )
Just use the banana bar. Sheesh.
[/QUOT
Glide slope will be above you as you must intercept below the GS due to a possible side lobe of the 90/150 Hz amplitude phases.
[/QUOT
What? What college are you pretending you went to?
Thousands of feet to descend: 20
Times 3
=60 miles out from fix
Ground speed times 5
GS:500kts
=60 miles out at 2,500fpm
Somewhere, a 727 captain is rolling in his grave at the loss of the mental 3:1 descent planning calculation...
Your math is easy and works well. However, if you want to be even more precise (and be able to explain why the math works), divide the altitude you want to lose by 300. (In the example, you get 20,000/300=67 miles out). This is because if you are descending on a 3 degree glidepath, you are descending 300 feet down for every 1 NM you go forward. Hence, the altitude to lose divided by 300 feet gives you the miles it would take to lose that altitude.
