HalinTexas
昇る太陽の土&#
- Feb 14, 2004
- If you are 200 miles out @ 310, ATC wants 110 @ 40 DME, when do you descent ( I WAS THINKING 80 MILES BEFORE THE 40 DME, ANY INSIGHT ? )
- At 2000 feet on localizer, 5 miles back, where do you expect glideslope to be (This one is confusing 5 miles back from where ? Typical 3:1 here however )
It's not as hard as it first looks. Here's how to do it easily (and impress your captain/fo at the same timeDividing numbers that large in my head makes me feel ill.
2. Your high
It's not as hard as it first looks. Here's how to do it easily (and impress your captain/fo at the same time):
Everyone knows that certain numbers are easily divisible by 3 (3,6,9,12,15,18,21,24,27,30,etc.). If you have to lose 18,000', it's 60 miles; if you have to lose 21,000', it's 70 miles. But what if your altitude is in-between those numbers? Notice that there are always only two choices (in this case 19,000' and 20,000'). The lower of the two choices will be 63.333 (call it 63); the higher of the two will be 66.667 (call it 67). The lower number will always end in 3, the higher will always end in 7.
Try another example: 13,000'--it's closest to 12,000', so the distance will be 43 miles. 14,000'--it's closest to 15,000', so the distance will be 47 miles. This always works, and with a little practice you can look at a number and tell instantly what the correct distance is.
This method is especially useful for the precision necessary for approach descent planning, particularly the op's original question about being at 2000' and 5 miles out--where is the G/S? At 2000', that's closer to 2100' (which would be 7 miles) than 1800' (which would be 6 miles), so you need to start down 6.7 miles out. If you indeed are at 2000' at 5 miles, you're WAY high! (You should be at 1500' at 5 miles). If you're still confused, just ask the guy sitting next to you.
Last Transmission was broken and stupid.
That's okay. Some pilots like to improve their mental abilities with age. Others prefer to be RJLosers their entire life. Take your pick.
Okay, rather than arguing, "you're simply wrong" back and forth, let's do the math and put this question to bed. I had always been told that you descend 300' per nautical mile in a 3 degree descent. If this is true, then my way would be the most precise, and your way would be "close enough." But let's see.3 X the altitude = distance.
18k=54 miles
21k= 63 miles
1 mile for 10 knots airspeed to lose.
You are making stuff way too hard and simply wrong.
You're under by 3.25 miles; I'm over by 2.75 miles. Therefore, my method is a tiny bit more precise (and a little more conservative for those who don't want to bust an altitude), but it's not "simply wrong." Bottom line, use whichever method you want; there's nothing wrong with discussing why each method works, though.
I know what you're saying, and technically you are of course correct. But in reality you aren't just going to make one mental calc and call it good for 60 miles, and just hope for the best. Things change along the way... Winds, TAS, temp, etc. So of course a good pilot is going to monitor his/her progress along the way for the crossing restriction. In the example given by the OP I would use 3:1 and begin my descent 60 miles out from the restriction. At about 30, I'd check again. I should roughly be around FL210. If no, then I'd adjust my descent rate accordingly. I'd check again at 20, and again at around 10.
VNAV or not, it's a very good idea to keep yourself in the loop. I used to fly an airplane that had more VNAV bells and whistles than most airliners out there (ProLine 21), but we still kept a check on things with a little bit of mental math.
It's pretty easy to get complacent with this stuff using VNAV and ATC in the USA, but even then there are times that you'll be left WAY too high if you're not used to quickly calculating a TOD in your head. Outside of the US, you'll definitely need to do this.
you guys r so gay
My eyes are bleeding...
How much wood could a woodchuck chuck if a woodchuck could chuck wood?
It's kind of sad that when you want to talk about pilot stuff on a pilot forum, particularly math formulas in a thread clearly titled, "Descent FORMULAS", that some of the responses would be so imbecilic. Whatever happened to intellectual curiosity, or even a vague desire to learn something new or become a more-informed pilot? Trying to be cool about being a moron surprises me most, though.
