JustaNumber
- Nov 10, 2005
I know what you're saying, and technically you are of course correct. But in reality you aren't just going to make one mental calc and call it good for 60 miles, and just hope for the best. Things change along the way... Winds, TAS, temp, etc. So of course a good pilot is going to monitor his/her progress along the way for the crossing restriction. In the example given by the OP I would use 3:1 and begin my descent 60 miles out from the restriction. At about 30, I'd check again. I should roughly be around FL210. If no, then I'd adjust my descent rate accordingly. I'd check again at 20, and again at around 10.
VNAV or not, it's a very good idea to keep yourself in the loop. I used to fly an airplane that had more VNAV bells and whistles than most airliners out there (ProLine 21), but we still kept a check on things with a little bit of mental math.
It's pretty easy to get complacent with this stuff using VNAV and ATC in the USA, but even then there are times that you'll be left WAY too high if you're not used to quickly calculating a TOD in your head. Outside of the US, you'll definitely need to do this.
Definitely great points, and you're right about how easy it is to get complacent.
