avrodriver
- Jan 31, 2002
Huh? My friends say the huge pay increase and restoration of longevity are appreciated. They are looking forward to bidding larger equipment in what they consider to be better bases this spring. They are happy.No amount of whining I do, nor anything you can expound on this forum is going to convince 2000/2001 NWA hires that they didn't get worked over on the arbitration.
They have put all of the major base moves on hold. With the new data they are seeing and a few other important factors, they are deciding to sharp shoot the movement than to just do it all at once.
There will be big jets moved, but it will take time.
I'd debate you with quotes from your own pilots on this board, but as RedRum has pointed out NOTHING would help you appreciate the position you find yourself in.Fail.
Being forever frustrated about something you can't change will not do you any favors. Might as well look at the good side, as most of your pilots have.
Yes Sir;Acl,
Can you elaborate? Specifically on the new data and other important factors? Thanks
The good of the situation is Redrum had his longevity adjusted to include his furloughed time. Time to let the seniority issue go. It's done. Bitching does nothing other than pissing off your colleagues.
