Delta Hiring
FBN0223
I have a friend who I recommended at NWA. He was hired but his class was cancelled. He'll be a strong contender again when DL starts hiring. Considering our current staffing situation, I think that's going to be awhile, maybe 3-5 years. Any other educated guesses on future hiring?.
Also I heard from the ALPA guys that Compass maybe getting their own ALPA representation and will no longer be under the Delta MEC. In the process, they would most likely lose their flow-up agreement.
That may not be such a bad thing. When Continental Express (later ExpressJet) and Continental were represented with the same MEC, there was a one for three flow-through agreement. One out of every three new hires was from Continental Express. When the MEC was split and the flow-through was terminated, there was no longer a limit to how many ExpressJet pilots could be in each new hire class and the ratio actually climbed closer to 1 for 2, and in some classes was nearly 1 for 1. In my class 11 out of the 16 new hires were from ExpressJet.
I wish for you to change your title, as it does not in fact state that Delta IS hiring.
Not true. The language is in both contracts and has nothing to do with whom represents whom. Anything could be negotiated but it's not really in either sides interest to change the agreement.
I'll probably piss off some compass guys and gals with this question. But here it goes...
I've always wondered the future of compass since it's restricted to 36 aircraft. Does this limit apply to all aircraft types or just the E175?
I think everyone would agree as a company grows older it's cost to operate usually increase. One big reason is salaries. And to offset this companies usually grow.
MEM and DTW are such small bases I have to question if they're even efficient to keep around in the future.
Just curious if anyone else has thought about this. I honestly don't know if compass is making tons of money or not. And if they have future plans or not.
Compass is not restricted to a certain number of airplanes. You're probably referring to the grandfathering of the Compass E175AR in to the Delta scope, because its MTOW is above the Delta max. Compass could fly more airplanes (E175 non AR for example) but they would not be exempt from the scope weight limit like the existing 36 are.
Sorry to interrupt the thread
That makes sense. Similar as Mesaba use to be with the Avro and NWA scope restrictions.
Many thanks
If Compass were to form their own MEC, and the flow-up agreement was negated, does that not mean the flow-down agreement is also negated?
This is the first I have heard of this issue. If this in the cards, I would hope that the flow-back agreement would stay in place. That was one of the negotiating points the NWA pilots obtained when the Compass brand was formed.
I know I don't need to explain how important this flow-up / flow-down agreement is to the Delta pilots right now. Without it, Delta could furlough and leave the junior, furloughed pilots without a job. I wouldn't be too sure about Compass terminating the agreement.
Simply put, I don't think they have a legal basis to do so. It is part of our Pilot Working Agreement (PWA)
Any one else that can speak to this?
