Delta AE Surplus Bid:
Sedona16
Delta AE Vacancy/Surplus Bid:
The August 2009 Advance Entitlement/Surplus bid will support the proposed last quarter 2009 and first quarter 2010 Network block hour plan. The following are the key points for this bid:
· This Advance Entitlement/Surplus bid is set to align our staffing based on the planned increased utilization of aircraft on the 73N and M88 fleets.
· The domestic 757/767 fleet was reduced and the domestic 757/767 pilot block hours continue to remain lower. This has resulted in surpluses on the ATL and LAX 767 Captain and ATL, LAX, and SLC First Officer positions. These surpluses will be used to increase our 73N and M88 staffing.
· We have decided for increased operational flexibility that we will continue what we started on the January bid and eliminate the LAX 767 categories and grow the LAX 7ER categories. A majority of the LAX 767 positions being eliminated are being added to the LAX 7ER categories.The planned flying for the LAX 7ER categories will include a mix of domestic and international flying.
· Due to the changes in the network schedule, we are seeing an increase in our system credit on the 73N. This increase in credit hours, along with the planned increased aircraft block hours, is driving increased staffing requirements in the 73N Captain and First Officer positions.
· Keep in mind, even though surpluses may not be posted in your category, as the bid is processed contingency surpluses may be created in your category so you may want to update your AE, VD, and MD bid preferences.
· This bid will be effective for 210 days.
· The projected training start from this bid will be September 2009 with all conversions being completed by March 2010.
· The next bid is planned for January 2010 and may be the first DL North and South combined bid, subject to SOC.
· Currently, DL North is in the process of awarding the final APA for the DL North pilots. This current bid award will include the closing of the 747-200 categories, necessary backfills for the PRIP participants, and other adjustments to align staffing based on the current Network winter and spring planned block hours.
We will continue to communicate any updates in the fleet and network plans as we continue to position ourselves for a successful future.
Number of
Category Vacancies Reason
ATL 73N CAPT 10 Increased utilization
ATL 73N F/O 13 Increased utilization
ATL M88 F/O 5 Increased utilization
CVG 73N CAPT 5 Increased utilization
CVG 73N F/O 10 Increased utilization
CVG M88 F/O 5 Increased utilization
LAX 7ER CAPT 94 Shift in Flying
LAX 7ER F/O 90 Shift in Flying
NYC 73N CAPT 5 Increased utilization
NYC M88 CAPT 10 Increased utilization
NYC 73N F/O 12 Increased utilization
NYC M88 F/O 15 Increased utilization
Number of
Category Surpluses Reason
ATL 767 CAPT 15 Adjustment
ATL 767 F/O 45 Adjustment
LAX 767 CAPT 109 Shift in Flying
LAX 767 F/O 102 Shift in Flying
SLC 767 F/O 3 Adjustment
Looks like you will still have at least 130 07/08 hires on the ER in NYC. Probably more, but that takes in to account all 45 going to the ER from the 767.
Just a side note, most of the ones that will be displaced on the 757 were hired prior to 07. Only the bottom 15 were hired in 07-08. It will be interesting to see how many will choose the ER in NYC.
Well it is an easy commute and it might be worth the extra 2-3K a month for a guy that flies a lot.
You have to work a lot harder to get what most got sitting reserve on the 767.
Very true! Can you guys hold ATL 73N?
ATL 767 to ATL -88 would be quite the shock to the system!
Depending on where other ER displacers came from I would think all ATL 767 guys would still be holding lines up in NYC.
Yes, the most senior 07 hires have about 180 bodies below them on the NYC ER and about 90 line holders.
Heck...might as well give it a go!
If they ended up not liking it chances are they'd be able to bid right back out of it when the chaos of moving the 767-400's in begins.
Nope the traffic sucks from Farmingldale too! There is no good commute to JFK. ATL to NYC is FULL of commuters good luck with that one. Then you have a 20 dollar cab ride and forget about it with weather or snow...
Could be worse. I'll take that commute twice a month.
