FlyChicaga
- Mar 23, 2002
This was brought up elsewhere on the internet about London-Heathrow, how often you will be given holds of 5-20 minutes inbound for arrival delays. This rather than provided vectors or constant speed adjustments. I was thinking about it tonight, and am surprised this isn't used more as a flow technique. It is not often that we are given holds, but in all honesty I'd say it might be more prefered. In a hold, you are normally provided a few things which are invaluable to a pilot:
- EFC time.
- Constant speed/fuel flow/flight pattern for fuel planning
- Position on one point to navigate yourself, rather than rely on vectors and traffic alerts
There are other benefits I'm sure. Plus, there are benefits from an ATC standpoint:
- "Set and forget." Leave the pilots to navigate, therefore focusing on approach vectoring
- You know a starting point to release an aircraft for approach, and the time it will take them to get there
- Pilots can inform ATC quicker and more accurate when fuel critical
- Less workload
It seems to me that inducing holds more often, and earlier, would be a much better technique to handle heavy arrival rates. I know that often times we can be given speed adjustments many miles out from the destination, heading changes, delay vectors. All these things will increase fuel burn and flight time, but you can't predict with great accuracy just how much fuel you'll burn in excess. So, we add on layers of contingency fuel, which can add up.
Thoughts? Particularly from our resident ATCers?
- EFC time.
- Less workload
