rumpletumbler
- Jul 3, 2002
rumpletumbler said:So declaring minimum fuel means that if you get any delay you are likely to have a fuel related emergency. Whatever happened to VFR/IFR reserves? Wouldn't you be visited by your friendly neighborhood fed if you declared minimum fuel? If not, why?
rumpletumbler said:If someone declared minimum fuel then I would think they were pushing it for no reason unless you had no other viable alternate. Why wouldn't you stop and get some gas rather than push it that close?
Rattler71 said:Declaring minimum fuel means you used more fuel than you planned and you are trying to stay alive. If the flight is at that point, the feds are the last thing on my mind. l
Rattler71
