Mad Dog 11
Yes, the MD-11 or affectionately known as the Mad Dog can indeed fly non stop from LA to Frankfurt. The payload would be roughly 140,000 lbs. depending on the season, direction and route of flight. It's about 12 hours to LAX, 11 to FRA. The OEW is roughly 257,500. Max T/O is 630,500, Max landing is 491,500, Max ZFW is 461,300. Max structural payload is around 204,000. Max fuel capacity is roughly 258,000. The pax MD-11 OEW is roughly 30,000 heavier depending on configuration so obviously it's not as capable as the pure freighter. 13 hours and 58 minutes is my personal max time aloft from wheels up to touchdown in the PAX MD-11. Max cargo I've ever carried is 202,100 out of Hong Kong. Basically campared to the DC-10-30 the MD-11 burns roughly 25% less gas, carries 25% more cargo and has 25% more range. Still the 3 holer is not as politically correct to the accountants as big twins. I love the plane, great performer, even at MAX TO it has plenty of thrust; each engine putting out 61,500 lbs of thrust. The plane never was very popular due to initial range shortfalls. Singapore airlines couldn't fly from SIN to Paris non stop, Delta couldn't fly from LA to Hong Kong non stop with full pax (roughly 275-300) and luggage and belly freight. Lots of software glitches. All the problems were addressed by Douglas but the damage has been done. Singapore cancelled their order, American had requested software engineers from Honeywell to be onboard revenue flights to trouble shoot nuisance messages.
Main problem was it had the basic DC-10 wing, Douglas at the time wanted to put on a new wing but the new wing was too expensive (new wingbox...etc...etc...) so they did the next best thing. Extended the wing a bit and added winglets. Reduced the size of the horizontal stabilizer by roughly 30%, active inflight C.G. control via fuel in the tail for AFT C.G. Other monor aerodynamic improvements and modifications. Even repositioned the windshield wipers from horizontal to vertical when parked. (This is one way to tell some of the older MD-11s)
The lastest MD-11ER has extra bladder tank in the belly if so desired with all the latest aerodynamic mods (most visible being the flap fairings which protrude beyond the trailing edge of the wing with a tapered end). The older flap fairing stops right at the trailing edge of wing. I think around 1998 to 1999 is when this fairing was installed. The ER has a range of roughly 7200 NM.
