stupidpilot
Registered Moron
- Sep 6, 2005
TheBaron said:No matter how ragged out, I never had a Falcon that wouldn't make 350. Granted if you took off at 28,660 you had to keep your speed way up in the climb or you would run out of energy. Push it over at 10,000, accelerate to 320-330 then let it bleed off a couple of knots per thousand feet. We had 14 Falcon's and there wasn't a single one that I couldn't get up to 390. Several I had up to 410 and two I had up to 420 on test flights after dual engine changes. Never give up your A/S or will will be stuck down at the lower levels. We had quite a few pilots that just couldn't figure that simple fact out. One guy popped engines every time he went above 350. I would take the same plane straight to 390 the next day on a maintenance test flight.
That's because you fly for a company that actually takes decent care of their aircraft.
