Side Question: Pitch Attitude
tarp, you said:
>And as to the AOPA report, I guess we're just reading it differently - my case is that a C-182 has a great history of nose gear collapses due to poor pilot technique
>I've also found that when landing the C-182 without full flaps, most people unconsciously lower that big nose just enough to see the end of the runway over the top of the cowling
It seems we agree
far more than we disagree.
You're right about trying to look over the nose. In fact, now that you mention it, I've never asked this question in this forum. This might be the appropriate discussion to raise it.
My theory about nose position is simple: In a tricycle gear airplane, your pitch attitude when you touch down should be the same as when you take off. When airplanes take off, their nosewheel leave the ground before th mains. If you touch down in the same attitude, you will not hit the nose first. Airplanes that tend to takeoff with a view over the nose (many low wings) land that way. And vice versa.
Using the 182 as an example, it's nose heaviness also means that the nose is a bit higher than you can see over when you takeoff. And, as tarp points out, you really need to have it stay up there when it lands.
I only fly single engines, but I've found it true in all that I have flown or ridden in - Cessna, Piper, Mooney, Cirrus, Diamond, Tigers, Bonanzas, maybe a couple of others - and it's been a big help to me when I learn how to fly something new.
Have you folks found this to be the case as well? I'm really curious about twins and whether its also true for the bigger aircraft.
