Iflyamouse said:Differences between the 701 and the 705: The 705 is basically a CRJ900 that is configured with 70 seats. They did redesign the wing to get an extra 300 nm range out of it. You'll see the redesign of the wing in the winglets, they stick out from the wing at about a 55 degree angle instead of the near 90 degree angle that you see on most RJ's. The first one won't be ready to fly for another couple of months. I believe it was Air Canada that wanted these. They wanted to be able to fly from Montreal to Vancouver year round so they ordered enough of these 705's for Bombardier to stick them on the assembly line. So far, no other carriers have ordered any.
I can't speak for many of the differences in the -70 and -90 except to say that the -90 holds 90 pax, has bigger engines, and performs about the same as the -50, maybe a little better. Nearly all the systems are the same between the --70 and the -90. The pilot reference manual (kind of a Bombardier POH) is the same for the 2 aircraft.
United Express' CRJ-700s is in a two class configuration but only one lav in the rear but it's a larger size than on the CRJ-200. I've flown on ASAs CRJ-700 and they have two lavs but just one class configuration. Different operators with different configurations.The 700 also has a forward lav.
No. Just advisory VNAV like on the CRJ-200.Are autothrottles standard on the CRJ700 and 900?
Ace McCoy said:A question off topic:
Are autothrottles standard on the CRJ700 and 900? And if so is there also vnav and autoland?
