That is the WORST thing to do in the CRJ sim. It flies like dirt. V1 cut is really, really, simple in the RJ as long as you do two things. After the cut keep it on the runway for 3+ seconds after the cut occurs. No where does your book say rotation has to be at Vr, it has to be AFTER vr, keep it on the runway to establish the rudder pressure needed to keep it straight, then SLOWLY rotate the aircraft. Run your v1 cut procedures and turn on the auto pilot ASAP. Then do NOT trim out the rudder, just keep some pressure on there. If you trim it out, every time you make a power adjustment you will have to make a trip adjustment, so don't trim it and rather use that time to worry about the automation. If you takeoff straight and stabilized the v1 cut in the RJ is easy and painless.
What on earth are you talking about? You responded to a quote regarding the use of automation by going on about the obvious. I stated that during a missed approach, when one is having trouble flying the airplane, get rid of the automation and hand fly it. You responded by saying that's exactly the wrong thing to do, and then went off on a completely different tangent. Drinking today?
Two issues have been raised here. One involves a V1 cut on the runway, and the other involves executing a missed approach with the autopilot.
In the case of a missed approach with the autopilot, if one is having troubles, then there's only one requirement; fly the airplane. Period. If automation is kicking your butt, get rid of it and handfly. Period. Yes, that's the right thing to do.
So far as a V1 cut...obviously one doesn't rotate prior to Vr. One does NOT need to engage the autopilot as soon as possible; if you can fly the profile without it, fine, but don't use it as a crutch. You're a pilot, not a button pusher. Exercise some competence, and fly the airplane. If you can't do that without automation, you have absolutely NO business in the cockpit. Period.
