The temp issue is an issue for sure with LiFePO4. I believe it's why my ETX-900 died at two years. I've had discussions with EarthX in the past about this as from what I learned of LiFePO4's is they cannot be charged below 32F (0C) or Lithium Plating can occur. It's been single digit cold in VA this past month so I know the battery has been cold soaked. While not on a charger, but once when I believe it was warm enough, once you go fly with a cold soaked battery, then what? EarthX or whomever it was recommended running the pitot heat 30 seconds prior to using the starter battery to internally warm it. I think that is a good idea but probably not enough to bring the cells where they need to be, uniformly. The LiFePO4 (Victron) batteries on my RV have a heating pad that is triggered by a thermostat. EarthX must come out with internally heated batteries and it sounds like TCW has done this. I know EarthX has their theories but my theory is if people knew they could not use the battery (charge) below 32F it would kill their business. I know what LiFePO4's need and this has been a big concern of mine. If this happens again, battery failure after two years, I need to rethink my options but probably consider a heating pad solution like my RV has.
I need to put a thermometer in my hangar. I know it's been cold outside but it didn't feel THAT cold in the hangar. But I need numbers.
