CMR Crash CVR released.
That'll work in a perfect world. So, you now no longer have intersection take-off approvals? What happens when visibility or contamination precludes you from seeing the actual runway number?
I spent 4 winters in the upper midwest flying Cessna 300 and 400 series aircraft for a 135 operator. We often flew from runways that were either partially covered or fully covered by snow to the point where you could not see the numbers. It was all too easy to line up on a wrong intersecting runway during poor visibility, so our SOP during taxi included checking alignment of the HSI against the compass and setting the heading bug to the departure runway heading. Once aligned on the runway, there was one last check of the heading bug. If it wasn't within 10 degrees of the actual heading indicated on the HSI, it was time to stop and find out why.
When I became CP for a 135 commuter we were flying EFIS equipped aircraft, but I incorporated into our SOP the heading bug being set to the departure runway during taxi and the double-check prior to adding power for takeoff, along with callouts by both the PF and PNF. Now that I'm in the corporate world, I still use this SOP on every flight.
Could it really be that Comair did not have something like this in their SOP prior to this accident? I'm wondering how their POI allowed such an oversight for so many years. This time, it proved to be a real killer.
I haven't re-read the transcript, but it sounds as if Eagle called for taxi after Comair, and took off first. I suspect their gate was closer? But in any event, the Comair crew would have seemed to be unaware that Eagle took off from a different runway.
But for the grace of God,...
This accident is an example of what could happen to any of us.
After reading the various reports (and if I'm interpreting them correctly), I have a few thoughts.
It sounds like the Captain may have just completed IOE 3 to 4 weeks earlier.
I think the F/O was older than the Capt.
The F/O mentioned that he had flown in the other night and "lights were out all over the place."
Looking at the Human Factors, this scenario can lead to a role reversal with the Captain relinquishing some decision making to the F/O. Had the F/O more specifically briefed the Captain that he had come in the other night and the 22 runway lights were working, but the centerlines, touchdown and REIL's were out, that might have been more helpful.
It appears that the F/O was surprised himself during the takeoff roll. He must have been thinking, "I didn't remember ALL the lights being out?", while the Captain (remembering the F/O's statement in the blocks) probably thought, "He did mention that 'Lights were out all over the place'".
The F/O also briefed "short taxi". At first blush, I thought that was good - giving the Capt heads up. But I suppose it could have added to the complacency of the Capt turning left too soon. Again, maybe it would have been better to be more specific and say, "short taxi - cross 26, then left onto 22.
Having flown most of my career out of smaller airports, non-tower, etc. anytime I'm operating out of a field that has runways that, if used, will kill me - I try to make a point of where they are and avoid them.
Tragically, this accident reads like so many others where there are many links that could have been broken, had someone put forth a little more effort. I personally have upped my own attention to detail.
RIP
Comair's SOP calls for bugging rwy heading or the assigned hdg, if a turn is to be made at 400' AGL. In this case, rwy hdg should have been bugged. However, I can't tell you how many people I flew with there who would pull on to the rwy and center the bug that I had set at the gate. Obviously, not the best practice. This continued to happen even after the accident and there has been zero change to the SOP's. I'm assuming due to concern by the company over liability.
Reread the trascript. They briefed flex takeoff.
It was, however, a full thrust takeoff according to FDR data. Sometimes it's misbriefed, sometimes it's briefed before the thrust setting is calculated, but I assure you full thrust was required and used with a 49,000 lb airplane out of LEX.
Thank you for answering my question. This means that flight crew either skipped over part of the SOP, or they simply were complacent and didn't notice when they lined up on 26 that their Hdg bug was 40 degrees off the nose before centering the bug. Ouch! That is painful to all of us.
