murfdawg998
CHAMP, HERE!!!
- Jan 28, 2003
\ A be-400 is under part 25 the afm does have two engine climb chart.
Landing climbWhat AFM do you have? SHOW me the 2 eng climb chart for a be-400.
Landing climb![]()
TrueIt says it in part 135. Under 91 there is no requirement to make the TERPS climb gradient in the event of an engine failure...
Smartttflyer said:If I can't meet the TERPS IFR, I depart VFR (if I can safely do so). If I can't depart VFR, I don't go...
Me too; however, that was then, this is now. In the past, comparative few instructors at the various training centers understood the concepts. Fortunately, the tide is turning and nowadays you are more likely be able to get the straight scoop in performance class.wantfries said:...I have got into heated talks with guys at Flight Safety about this...
That happens alot in ASE.. If you see 3 heads in the tower, one is an FAA guy watching to see where your going. Beechjet w/5 souls from ASE to CLT? Expect a visit when you land.
thats straight from the FBO. they say it happens alot.
but were does it actual say "in case of engine failure"
