DING DING DING
you either circle at mins or just say screw it and go to LAX.
CLOSE SMO
DING DING DING... not so fast johnnyride24.
Circling is not allowed on the "Circling" VOR-A approach into SMO. Yup, can't do it AND they won't tell you you can't until you start your circle to land move.
A LOA exist between LAX and SMO that basically does not authorizes the circle to 21 because there MAY be a loss of separation between LAX arrivals/departures and SMO traffic for rnwy 21.
The frustration is that they will not tell you that, either by NOTAM or a friendly head's up from SOCAL or SMO twr...
More Gouge:
Waypoint CULVE is probably NOT in your data base and will not show on the NAV or PFD... descent gradient from CULVE to rnwy 21 too steep!
From CULVE to 50' over the threshold of rnwy 21 requires (Appr. speed of 125 kias) a 5.6 deg. glide down and 1234 fpm rate of descent down... hardly a "stabilized" approch. BTW, there is an offset from CULVE so a lineup correction and corresponding re-correction will be required.
Depending on the Wx at the field... when SOCAL hands you off to SMO twr and you check in with "so & so approaching BEVEY for the VOR 21", you will hear from SMO twr, "So & so you are cleared for the visual, runway 21...". What that really means is that they have assigned you the visual approach, that you did not ask for because you have already been cleared for the VOR-A approach. Translation: you DO NOT HAVE THE MA airspace for the VOR-A approach.... yup.
Also, coming into SMO from the NW over VNY; they will always turn you inside of DARTS at 4500-5000', count on it and plan accordingly! BEVEY is in your face and you will be higher than you want.
Re: MA, forgetabout it... it'll be: "Fly headin 250, climb to 3000, contact SOCAL.
If for some reason your on the VOR-A and the field is less than 1000' and 3 and you see the rnwy... you'll still have go to CULVE at 1120' (and probably loose sight of the runway in the marine layer) and do the acro maneuver to land... I know, ask for the "Contact Approach"... nope, they can't approve it!!
I hate that f'n place because of all the secrets that they don't clue you in on... If you are not familiar with SMO specifics, you will not get "gouge" until you have been in/out of there many times before, unfortunately.
