Palerider957
- Jan 30, 2003
The S-II has a different wing than the II, plus it uses alcohol rather than boots for de-ice. The engine is about the same, but you run higher temps. All this makes it outperform the II, but hot section inspections are much more expensive. Cessna replaced the S-II with the V that went back to the old wing and larger engines.
