C425Driver
- Dec 5, 2001
Actually you can get a C500 SIC required type rating. If you take your initial C500 type ride in a C501 or C551 and use a SIC for the type ride your certificate will show C500 SIC required.Flyerjosh said:There is no SIC required restriction on any CE500 type because the plane was only certified for two pilot ops. You can get an addition to your type that would say CE5x0-Single Pilot (It's for a particular model IIRC). To do so, you need to do SP training in the sim, do a SP checkride in the sim, then do a
single pilot 15% ride in the actual aircraft with a DE or fed.
To my knowledge, you can get single typed in any of the 500 series aircraft (one of the pilots on the field here is SP typed on the Encore/560)
