Typhoon1244
Member in Good Standing
- Jul 29, 2002
By the way, about the "Chem Tail" photo:
I've been studying this photo very carefully using PhotoStudio 2000SE. Nevertheless, I'm unable to say conclusively what type of aircraft it is. The shape suggests a Boeing 737-300 or later model...but the fact that the mainwheels are not visible is still causing me to lean toward saying it's a 767-200. It could also be an Airbus A320. The fact is, the photo's too grainy for me to be sure.
I am certain, however, that the underside of the fuselage is white or light-gray, and the visible portions of the upper fuselage are white. This is consistent with the paint scheme adopted by Continental Airlines, as well as some of the "Special" paint schemes used by Southwest Airlines. (Air Canada is also similar.)
In any case, identifying the specific aircraft type is unimportant because aircraft in the photo is not spraying anything from it's horizontal stabilizer. How can I tell? Because if you look carefully at the starboard contrail (the one closer to the bottom of the screen), you can see that it is forming well forward of the tail, just behind the engine itself. It's more obvious if you convert the photo to a negative and/or use some color equalization effects.
So what have you got a picture of? A commercial airliner leaving a pair of contrails in its wake.
