Dangerkitty said:Tell that to the Falcon 50 Crew that took off from TEB only to be back on the ground in less than 3 minutes due to a spark from an Entertainment system that had chaffed the oxygen line. The oxygen line started leaking out O2 and there was an immediate fire fed only from the Oxygen. I talked to the crew of that incident personally up at FSI TEB and it was a scary story to say the least.
Out of all the dumba$$ idiotic statements I have read on flightinfo yours is close to being the dumbest.
Oxygen just helps the fuel burn at very high temps. Too little or too much, and the fuel won't burn. Oxygen itself is NOT flammable, but add a spark to the perfect amount of oxygen and something that's combustable...........and you'll have an intense fire!
Example: Oxygen and Acetyline (spell?) torch. Adding oxygen creates an intensly hot flame. I can't light the oxygen only, no matter how hard I'll try.
