CAL aborted landing problems in DUB (twice)
DUBLINFLYER
Airliner landing had to be aborted twice
By Pat Flynn
Friday March 19 2010
A TRANSATLANTIC flight with 162 passengers on board had to abort two attempts at landing at Dublin Airport yesterday after earlier being forced to return to the airfield with technical problems.
Continental Airlines flight CO-127 from Dublin to Newark in New Jersey (US) was due to depart at 9.55am but didn't leave until 10.18am.
After unsuccessful attempts to resolve technical problems which developed en route, the crew turned back to Dublin almost two hours after taking off -- but their woes did not end there.
On its return to Dublin, the flight had to abort two separate attempts at landing before finally touching down safely a further 40 minutes later.
The pilot initially reported a "maintenance problem" as the reason for the unscheduled return to the airport. However, it later transpired that the problem related to pressurisation.
The Boeing 757-200 jet was climbing through 25,000 feet after leaving Dublin when the crew requested permission to turn back.
In a statement, a Continental spokesperson said last night: "Flight 127 returned to Dublin because of an inoperative auxiliary power unit and an engine bleed-air problem. No emergency was declared.
"The aircraft landed safely and the customers disembarked. The aircraft is being repaired and is scheduled to depart Dublin at 11.00am (Friday) as flight CO1970. Some customers are being rebooked on alternative flights."
- Pat Flynn
Irish Independent
http://www.independent.ie/national-news/airliner-landing-had-to-be-aborted-twice-2104301.html
Need...more...Guinness...Must...turnback...
So pressurisation (Irish spelling) is not a maintenance problem? Good to know!
They heard the Scheds were rolling days off in Ewr and said no thanks I think I'll just stay another day.
or
It was a weekend and wanted to wait until the Monday issues of USA today, Walstreet, and NYTimes came out. I hate that stupid USA today weekend (INTL version)
or
Heard about CAL's counter, spit coffee all over the place, shorted out those crappy EFBs that were MEl'd anyway because they were out of date, tried to clean it up but the F/As were too busy discussing last nights rave and used up all the printer paper.
Any of the 3 are plausable.
Must be a slow news day. There were VERY high winds that day in Ireland and they were above the crosswind landing limitations of the airplane. Crew did what they had to do and didn't force the issue.
Too bad the media can only see the negative side of things. All journalists who report on the aviation industry need to be lined up against a wall and shot and or be trained as a pilot.
P.S. The Brits and the Irish need to learn to spell.
The Brits and Irish as well as other commonwealth countries speak and write the Queens English(Oxford dictionary) - not the bastardized version in the US
Are Xwind performance numbers considered a limitation? I don't have any jet experience but it seems like every P.O.H. I've seen points out that the max tested X-wind figures are not a limitation. That being said, they went around twice because they didn't feel it was safe to land.
For certain jets they are, or they may be a limitation per the individual airline's ops specs. For example when I flew the E145 our crosswind numbers were recommendations, but at JetBlue the numbers for both the 190 and 320 are limitations.
They are in the Limitations section and are "recommended" limits. I take that to mean a limit and thats thanks to lawyers. Imagine what would happen to the crew if they tried to pull of a landing 1 knot above the "recommended" speed in the LIMITATIONS section.
