C172 into Orlando International
ericpj14
Member
I am planning on flying into Orlando International this weekend to pick up my dad. I will be flying a C172 and was planning on going to SIgnature as an FBO. I will be going IFR, but was wondering if anyone had experience with this sort of thing or had an advice/discouragement. Thanks in advance.
Maintain best forward speed! :)
I have used Signature in West Palm Beach, and they are a great FBO. Make sure you check on landing fees for MCO. Although I have only landed Orlando's smaller airports I have heard many conflicting stories about how friendly MCO is to general aviation.
Ali
MCO is fairly accomadating to GA traffic, they have 4 roughly parrlell runways so getting in and out shouldn't be a problem, and signature is a great FBO.
I fly small aircraft into primary class B airports pretty regularly, so I'll advise a few things, though most of them are common sense. First, it is good that you're going IFR-that will make it easier for the controllers to plan ahead to fit you in. Second, make sure you are very familiar with the airport's procedures if possible. For example, if winds are ___, you assume that runways _____ are in use. This helps with general situational awareness, and is important with the third piece of advice I have: remember that when you're on the ground, the flight is only half over. GA pilots can make themselves pretty dangerous by not knowing where they're taxiing, which brings up this: if you are not sure of something (being cleared to land, what aircraft you're supposed to be following, route of taxi, ANYTHING) please ASK the controller and get it right! Also, be sure you are familiar with wake turbulence avoidance. Other than that, stick to your good IFR habits and it will be fun. As long as you are smart and proffessional, no pilot flying heavier iron or an impatient controller will care how big your destination airport is. I've never had a hard time flying into MCO, it's so spread out and never seems to be overly busy. If you're a little apprehensive that's good, it means you're probably not careless. But after you do this, if you do it right, you'll realize how simple it was and you'll grow as a pilot.
I have done a couple of instrument approaches at MCO in a Duchess and they were both after midnight. I was told that the MCO controllers don’t like GA aircraft in their pattern during the day. I would think even more-so on the weekends. If they let you do the approach you will have to do it at your maximum forward speed, which in a 172 is considerably less than that Delta 767 doing s-turns behind you on final.
MCO has 3 parallel runways and a 4th under construction on the far east side. Be ready to have a back-up plan. Orlando Executive is about 14 miles to the north. Your father might have to catch a taxi and meet you there in the event the MCO guys say no. At any rate good-luck, it will be interesting.
:cool: :cool: :cool:
If you are going to MCO to full stop, they will accommadate you, but may ask you to fly final at 140 kias! (Maintain best forward speed.)
Signature is fine, very anal about security, but you are at a major international airport, so it is understood.
Landing fees and airport taxes are applied to the fuel purchase...make sure you buy fuel (I think 25 gal min. at almost $3.50/hr last time I was there) or they will "pork" you with the landing fee!
Review getting your departure clearance and be prepared for vectors, altitude restrictions, etc and don't freak when you are facing a 767 opposite you on the runway at the hold short line...
Enjoy!
Airport diagram
Look at MCO's airport diagram before you're even in the air. Know where your FBO is already. When you get there, pay attention to your taxiway exit so you'll know which way to go to get to the fbo.
MCO and GA
The Orlando controllers won’t care too much, the only thing they really don’t like are practice approaches. But you are going to land not just shoot the approach and touch and go. So I would not anticipate any problems. Be ready for them to bring you in 90 degrees to the landing runway, and then turn you in last minuet. Have fun and watch for wake turbulence.
Hmm I was under the impression that they finished it. But the MCO guys should let them it as long as it's not a practice flight, I know people that take C152s there.
PA-44-typed: Is that a Riddle Seminole, that is it doing on grass I thought those were forbidden to take Riddle aircraft to. Kind of stupid rule so I don't care if it is.
MCO is no big deal. Expect 18R or 36L. I've made the flight numerous times in a PA 28 and never had them ask for anything more than best forward speed. I'd suggest Galaxy as there are no fees and fuel is cheaper. You can use their crew car to pick up pax at the main terminal.
It's not an ERAU Seminole... Just a standard Piper marketing shot. You can see the New Piper logo in the corner.
*edited for typo
If you are already comfortable in controlled airspace, you should not have a problem.
I like Galaxy at PBI, so if the culture is the same at Orlando, go there.
Best forward speed is important, that's why it is being mentioned several times. I used to take Archers and Skyhawks into PHL, and used to shoot the ILS at over 130 kts. Break out, power back, flaps, land. Be fully configured at the DH, or shortly after that if you break out just above minimums.
Whatever you do, exit the runway promptly. I had to go around at Dulles last month with two important pax on board, because a commuter dawdled on the runway. I don't need to tell you what that cost in fuel money. Make friends, and keep your speed up, and exit ASAP. Everyone will like you.
Study that airport diagram. Check the taxiways at your normal landing distance, and where the FBO is located. Do you have to cross runways to get there? If ever in doubt, ask for a progressive taxi. They'd rather hold your hand for a few minutes than pick up a pen and fill out a runway incursion report.
Do everything right, and you will look back on this flight fondly.
Good luck.
MCO
We took FSI students into MCO when I was there ten years ago. It was no problem at all. We never went IFR, but never had a problem at all entering VFR.
I agree with the others about doing what you can to maintain best forward speed until you hit the FAF and even afterwards. You might consider maintain 100+ kts until short final and even consider a no-flap landing.
You should have no problems. Enjoy the flight and let us know how it went.
Everyone has already covered most of the important stuff. As far as major airports with Class B airspace go, MCO is probably one of the easier to deal with. As someone already said, you can plan on 18R/36L for arrival. Most airlines use 17/35 and 18L/36R (although they sometimes use 18R/36L for arrivals). The FBO's are just to the west, so you shouldn't have to deal with crossing runways or much air carrier traffic, though you will be around the cargo guys.
Try to arrive early afternoon if you can. The push times for arrivals are typically around noon and after 5pm. Controllers down in Florida are friendly and relaxed for the most part. I see quite a lot of GA traffic at MCO, so you will be fine. Just to echo what everyone else said, keep your speed up and be aware of wake turbulence.
Good Luck!
flyboy said:
Orlando Executive is only 5-6 miles north of MCO.
Yes but ironiclly it's harder to get in and out of than MCO. Half and hour on the ground is not uncommon on the weekends.
Has anyone else had "issues" with controllers in the SFB tower?
I went up there the other night and they were real "Richards".
Chunk
