buthole captain
KSUPILOT said:
Well I am sorry I ever even posted anything on here. I am offically signing off from this website. You can not post anything on here without getting someone to blast on your question.
Don't go away mad...I was thinking about the comfortable comment, then this gem came to mind...
NTSB said:
NTSB Identification: CHI97MA017 .
The docket is stored in the Docket Management System (DMS). Please contact Public Inquiries
14 CFR Part 91: General Aviation
Accident occurred Wednesday, October 30, 1996 in WHEELING, IL
Probable Cause Approval Date: 3/31/1998
Aircraft: Gulfstream G-IV, registration: N23AC
Injuries: 4 Fatal.
The flightcrew of a Gulfstream G-IV began taking off on Runway 34 with a crosswind from 280 deg at 24 kts. About 1,340 feet after the takeoff roll began, the airplane veered left 5.14 deg to a heading of 335 deg. It departed the runway, and tire marks indicated no braking action was applied. One of the pilots said, "Reverse," then one said, "No, no, no, go, go, go, go, go." The airplane traversed a shallow ditch that paralleled the runway, which resulted in separation of both main landing gear, the left and right flaps, and a piece of left aileron control cable from the airplane. The airplane became airborne after it encountered a small berm at the departure end of the runway. Reportedly, the left wing fuel tank exploded. The main wreckage was located about 6,650 ft from the start of the takeoff roll. Examination of the airplane indicated no preexisting anomalies of the engines, flight controls, or aircraft systems. The Nose Wheel Steering Select Control Switch was found in the "Handwheel Only" position, and not in the "Normal" position. The pilot-in-command (PIC) routinely flew with the switch in the "Normal" position. The PIC and copilot (pilot-not-flying) comprised a mix crew in accordance with an Interchange Agreement between two companies which operated G-IV's. The companies' operation manuals and the Interchange Agreement did not address mixed crews, procedural differences, or aircraft difference training.
The National Transportation Safety Board determines the probable cause(s) of this accident as follows:
failure of the pilot-in-command (PIC) to maintain directional control of the airplane during the takeoff roll in a gusty crosswind, his failure to abort the takeoff, and failure of the copilot to adequately monitor and/or take sufficient remedial action to help avoid the occurrence. Factors relating to the accident included the gusty crosswind condition, the drainage ditch, the flight crew's inadequate preflight, the Nose Wheel Steering Control Select Switch in the "Handwheel Only" position, and the lack of standardization of the two companies' operations manuals and Interchage Agreement.
I know I'll regret this, but here goes ...
I'm willing to bet I'm the lowest-time wannabe sitting right seat in a multi-turbine aircraft here, and my boss does the full boat on every single leg. I've learned all the challenges, responses, and actions for every normal procedure in the B200 (even though I'm still stumbling :D), and he uses them religiously. So here I am, trying to learn how to hand-fly this huge/fast (to me, being a Skyhawk weenie) aircraft, manage my own power, and still run the checklists at less than 300 hours. And for the life of me ...
I can't figure out what the big deal is?
And as anyone who's flown with me will attest ... I don't exactly fly like Chuck Yeager, and I ain't the sharpest knife in the drawer to start with. :D
I'm glad my boss does the full, two-crew checks per the Simuflite manual, even though he has thousands of hours doing by his lonesome.
I be learn'n ... and I be comfortable that way. :)
Minhommad the Muslim Pig Farmer
pile on
Hugh Jorgan said:
Good grief, 15,000 hours and the after-takeoff checklist above 1000 agl is scary? How the heck do you manage to do the before landing checklist when it's busy and you are at 1500' agl? Next thing you know, he'll call for the after-landing checklist while you are still taxiing in!!! The nerve! (BTW...two T's in butthole, since Tonyc doesn't seem to be paying attention today).
I think it should be hyphenated "butt-hole"
Weird
I think I'm going to start blurting out "sterile cockpit" anytime I don't want to trade in-flight meals.
You've got to have thick skin when you fly with a jerk. It's tough to do that when you're on a multiple day pairing, but it's just part of being a good pilot. A lot of people can fly airplanes. Getting along with crewmembers you don't like is the real test.
If there's something beyond that, such as a safety issue...remove yourself from the trip or better yet, discuss it with the captain.
Once you become the PIC, remember those things that you didn't like when the shoe was on the other foot.
A "Butthole" Captain is no different from any other cockpit anomaly that has to be managed. Engines fail, hydraulics leak, generators drop off line and captains have brain farts. Just another situation in the life of a professional pilot.
Why not take the original post and substitute an aircraft system for the "butthole captain" and I think you will see the weakness is not the frailty of the offensive captain, but the inability of the first officer to cope appropriately.
After serving 16 years as a first officer and another 18 as the ______ (you fill in the blank) captain, I can tell you that personalities and personal foibles are a fact of life in the cockpit. It is just as important to be able to manage a malfunctioning crewmember as it is to manage an engine failure...maybe more important.
Copilots fall into two major categories: co-operators and competitors. Co-operators work with the captain to complete the assigned mission. They are respectful of the captain's position and understanding of the captain's limitations. Competitors are copilots who are continually vying to prove their superiority to themsleves. They understand NOTHING of the correography of the two man cockpit. They try to do the captain's job better than the captain while neglecting the tasks that the captain counts on the co-pilot to do. For the co-operators, CRM is a guide to a peaceful, safe operation. For the competitors, CRM is a manifesto of "you're not the boss of me". A four day trip with a co-operator is a pleasure. A four day trip with a competitor is a nighmare.
Being a copilot is much harder than being a captain. To play a good second fiddle, you gotta listen to the tune of the first fiddle. Harmony, or cacaphony...what's it going to be?
probably a lot of truth in mooneymites post. but i am sure he will be labeled "old school" or "old fart", but not by me. :)
KSUPILOT said:
So Iam flying with this buthole captain this week. He has a serious case of Captainitis. I do not feel comfortable being in the cockpit with him. I could sit here and right a four page letter on why I do not feel comfortable but the biggest thing I am trying to get over is his excessive overkill of command and response. The times he wants to do it scares the piss out of me. Give me your thoughts. He has called for the after takeoff check list between 1,00o and 2ooo feet of the ground coming out of busy airports. Today he wanted to talk about comnad and response at 6,000 feet in the climb coming out of a High dentsity Airport and I refused and called out "Sterile Cockpit". What are your thoughts on the commmand and response overkill?
THanks,
KSUPILOT
No offence or anyting but if you've got 15000 hours this couldn't be the first time you've come across a butthole crewmember with whom you have to work with. By this time in you career you should know how to deal with this type of problem.
Ebony and ivory live together in perfect harmony
Side by side on my piano keyboard, oh lord, why don’t we?
We all know that people are the same where ever we go
There is good and bad in ev’ryone,
We learn to live, we learn to give
Each other what we need to survive together alive.
Side by side on my piano keyboard, oh lord why don’t we?
Ebony, ivory living in perfect harmony
Ebony, ivory, ooh
Paul McCartney
atrdriver said:
Last time I flew with a Captain that felt it necessary to nit pick at everything I did I said "your controls". After he took them he asked me why, and I told him I didn't need flight instruction and he could fly the rest of the trip and I would take care of the radios. He said he didn't want to fly all the legs for 4 days, so I told him to keep his opinions to himself unless it involved safety.
I love it ATRDRIVER!! LMAO
