skydivinguy said:You didn't say contol surface, you said parts were hanging on by the bonding strap. Not sure what you work on but only control surfaces have bonding wires where I am.
Well have you worked on many airplanes? Control sufaces are not, by far the the only thing that has bonding wires. Most everything in airplanes are bonded somehow, even composite parts. Ex. Vertical stab tip Do328 blown off in lightning strike (bonded). Wing tip(s) Crj200 blown off about 6 in worth. Never even touched the static wick. Holes blown in fus. on jets What about the bonding wires then. Doors are bonding wired. some lights are bonding wired. most electronics, and yes bonding wires are mel'd alot. All im saying is its a bonding wire.
