erj-145mech
- Aug 13, 2002
erj-145mech said:If there aren't any static wicks on the flight control, then the bonding wire serves absolutely no purpose what so ever.
Common sense must overcome stupid behavior.
skydivinguy said:ding ding, you're right!!!
I've seen several A/C hit by lightning. Usually on a prop tip and usually exits off the rudder and or elevator. Seen static wick bases gone but control surfaces blown off or hanging by the bonding strap? Gimme a break!!!!
Avimec said:Where did i say........control surface??? I cant find it maybe you can help me. You are right in a prop plane usally that is what happens. good job! But it dosent have to happen like that, it can hit the top of wing and punch holes in the belly every 2 in. or blow of a winglet. But none of that was the point All i said was its only a bonding wire, yes get it fixed when you can, but its not flight critical!!!! All i'm sayin.
