FearlessFreep
- Feb 23, 2002
I have owned a Bose X headset for about a year. Recently after having not using it in a while (furloughed) I started using it and noticed that on occasion if there is any sort of bumping or vibration that contacts the headset the ANR function will shut off. I have also found that even just sitting there without touching the headset the ANR would just shut off. I tried changing the batteries out and this did not have an effect.
I just got off the phone with Bose tech support and they informed me that it was the Ear Pads. The ear pads are specially acoustically engineered to work in conjunction with the ANR electronics. The foam that they utilze has special acoustical properties and as such MUST be replaced with OEM pads or the unit will not work properly.
This is the kicker - the tech stated that the rated lifetime of the ear pads is...200 hours of use. My usage of the headsets turned out to be about 270 hours, so that is pretty much on the mark.
If I would have known that I was paying $980.00 for a headset in which I would have to dole out an additional $20.00 for every 200 hours of operation over and beyond the cost of 9 volt batteries I would have given this purchase much more serious consideration. A lifetime of 200 hours of usage at $20.00 a pop is totally unacceptable to me. I will have to start looking for an acceptable replacement.
On top of this in October I ordered the mike/pendant update for the headset. That was supposed sent to me by now. I was now informed that the date of availability has no been pushed out to mid December. The support of these headsets are for me a big surprise since in the past I have always dealt with David Clark and have never had any problems. DC headset operation has never had the proviso of not properly operating after 200 hours of usage.
If anyone has any suggestions for an alternative ANR solution for use in a 3 crewmember jet please let me know what it is.
If I find an acceptable replacement there will be a pair of Bose X headsets available at a fire sale price!
