Bose QC2 w/ Ufly Mic - earbuds now required by FAA
So do you have to have the buds available, or do you have to use them constantly?
goodgig,
Constantly. All you need is to be able to hear that audio is coming out of them, so just putting one/both in an earcup works. Much like having overhead speaker on as a confirmation that QC2 audio is working. This meets the "pass through" requirement for ANR headsets.
It solves a non-problem that never existed.
Mike
I think most people would prefer it if you spent your time making a fail safe product rather than trying to justify the deficiencies of your current product.
I've had exactly two headset failures, and both have been with TSO'd units. (One lost audio in the earcups, and the other snapped in half an fell around my neck.)
How exactly did the TSO help make them "fail safe"?
CA1900,
Good point. The audio from the earbuds is independent of the QC2 and comes directly off the comm panel. Is it "fail safe?" No. But, it's the only headset on the market that now has redundant audio.
Nothing is, but there's a faction that have an unfounded fear of a battery powered headset. To me, monitoring a battery is no different than monitoring the fuel, oil and oxygen in the aircraft... well, almost. If your headset quits you don't normally fall out of the air....
Mike
There is big difference between an unplanned mechanical or electrical failure and a product that is engineered to be unserviceable when something like a battery dies. I'm not saying the TSO certification is the holy grail either. TSO or not something like an aviation headset should at least be engineered for the environment it was intended for. In the case of the QC2, it was never meant for the flight deck.
DoinTime,
The QC2 passed the same TSO specs as the Bose X. Ever listen to the so-called "pass through" on some ANR headsets? Some are unusable; other ANR headsets go dead when the battery dies... you have to turn the power switch off to regain any audio. They all have shortcomings.
FAA CMOs are not authorized to evaluate operational policies of air carriers.
I'm afraid you're completely incorrect on that one. While operational policy outside of regulatory requirements does not need to be approved, the CMO does have the authority and certainly does evaluate that policy. Whether the carrier chooses to implement recommendations from the CMO is their choice. There is no question that the CMO does and should evaluate all aspects of a carrier's operational policy.
To answer your question in specific-should the ANR portion of your headset fail or power be lost to the ANR portion of the system you would still be able to hear ATC at some level determined to be acceptable.
To answer your question in general, nothing...the PMA/TSO'd manufacturers just have to pay more in liability insurance and meet various requirements in their manufacturing facilities.
The bottom line is that as a professional pilot you need to meet the requirements of your GOM and other company publications and the FAA.
This leaves you with two choices. You can use the sheitearse D-C or Telex headvices or inaudible crappy devices your company provides or you can go out and pay for some honest to God FAA PMA/TSO'd aviation headsets with or without the ANR and with or without the cellphone/ipod input connections.
You're the one that wants to be a professional pilot...guess you need to live within the rules.
Sorry that your union didn't negotiate you a better deal!
I am sure someone here will have no problem correcting me if I am wrong, but last I heard the Telex 750's are not TSO'd. Does that mean that we cannot use them going forward? If so, I'll add the earbuds to my QC2/UFM, I only carry the Telex as a spare anyway since I got the QC2/UFM.
The TSO'd headsets both gave out with no warning. Should the same thing happen with the QC2 setup, the solution is the same: turn up the speaker knob.
And that's exactly what I do. My GOM says nothing about using a TSO'd headset. Nor do any of the FAR parts under which I currently operate (135, 91, 91k), or part 121 for that matter.
Three, actually. A non-TSO'd headset is completely legal. Please show me where the FARs requires a TSO'd headset.
Please see above.
I'm completely happy with the deal my union negotiated. What does that have to do with this?
Unless your airline requires you use a TSO'd headset then nust buy the QC2 and UFlyMike and have a blast.
No earbuds required.
Gup
Telex 750's are TSO'd I believe.
On another note, I believe all Lightspeed ANR's (zulu's?) are not TSO'd. I have an older pair, and they do not lose audio when the battery fails. However, I believe they don't pass the test because radar can interfere with them. Which equals a 1/4 second tone 0-2 times or so a month, and only when at a field with radar on site......... Or maybe my set has just been beaten to a pulp over the years.
Mike,
So why don't you make your own 'headband' for the UFM, instead of relying on only one specific headband, the QC2, which is not, according to Bose, a TSO'ed product?
Rekks.
By the way, if a company writes a requirement for a TSO'ed headset requirement, and the FAA authorizes it's inclusion in the companies FOM, then it IS regulatory in nature. Period. And just because the manufacturer of the aircraft did not include headsets as part of the certification does not override the operators requirements, as outlined in the operators' FOM.
Mike,
We're working on it, although we don't have to have Bose' permission. If you consider all the pieces and parts in a TSO'd article, there is no requirement to get each manufacturer's permission to use their part in a TSO'd article. That applies to Bose, also.
Mike
Copied from another board:
1) From the QC2 Owners Manual:
Other needs
These headphones are not engineered to meet the needs of pilots or to meet civil aviation authority standards for aviation communications.
For that purpose, Bose offers the Aviation Headset, which features a microphone with the appropriate power and intelligibility for transmission of flight information. It is engineered to withstand the altitude and temperature conditions common in non-commercial aircraft.
For information on the Bose® Aviation Headset contact Bose Corporation by calling 1-508-766-1099 or +31(0)299-390777.
Don't we fly Commercial Aircraft???
Of course they are going to say that, (dramatically as possible) They have much more profit margin in their aviation headsets.
I used to own bose speakers (live and learn), and really have very little respect for most of their products. I would never lay down a grand for their headsets, even if they were worth it.
Mike
Blackey if you were a congressman maybe the nation would know how much b.s. the stimulus legislation is.
So what about my TSO'd, battery less, painful, and piece of crap, company issued headset which failed, without warning, last week? I guess that one is ok.
http://www.honeywell.com/sites/aero...770_H6B56709F-3C71-3B17-8FE6-B372A64AA28C.htm
"If the part successfully passes all the tests, then the manufacturer will receive a letter from the FAA stating the part is approved per the TSO. This TSO approval letter means the part is eligible for installation in any aircraft via an STC or TC as long as the operating environment of the part in the aircraft is within the TSO criteria."
so, i assume all of you TSO'd headset disciples have the TC or STC certificate that incorporates your headset into the aircraft type design.
what's that? you don't? ooh, i'm telling!!!
GOM states that while the company provides headsets (crappy Telex headsets) the use of personal headsets is allowed if they meet TSO-92 or whatever the hell it is...
Since these headsets are used in-not "installed" in the aircraft and the mic power and impedance and headphone impedance are all aircraft standard you can do it the same way you can get away with plugging in a portable intercom or GPS reciever in a light airplane.
This is in stark contrast to plugging in your silly computer/MP-3 player headphones into the aircraft...
Belchfire,
Your statement would be true except there is no such thing as "aircraft standard" since DO-214 and DO-160, which govern TSO standards, are full of "standards" but there is no guidance about which ones to use for a TSO Authorization. A manufacturer can choose a "standard" fail to meet it and STILL get a TSO as long as the failed standard is listed as a "limitation" in the user guide for the TSO'd article.
Second, the "silly computer/MP-3 player headphones" you refer to are in compliance with the same TSO standards as the Bose X. They were tested under the same conditions and to the same standards at Sun Laboratories, a very respected facility. Results are on file with the FAA.
The statement by any organization or person that a headset "must meet TSO standards" shows that organization or person doesn't know what they're talking about. There are 23 environmental categories under DO-160 and DO-214 is an inch thick and full of "could" "should consider" "might" and varying test methods. There is NO such thing as "meets TSO standards..." in reality.
