AK tightened scope is not the same as being gone, should USair AMR happen. Yes UAL has plenty of 70 seaters, but so did DAL have prior to C2012. The number of hauls allowed is an exact copy of your scope. So again your cap is the same as the JCBA cap. Either UAL gets 100 seaters and allows up more 76 seaters like the ones DAL bought today, or we have less of those flying around. Pay rates of the EMB 195 are just like the rest of the rates, same percentage diff with DAL as all other. Not sure what you are getting at with that one. Also the additional 76 seaters can only occur if one of the these models is purchased the C1000, EMB 190 or EMB 195. Which each of those models they be lucky to get 100 seats in with F, Y plus and Y.
The whole point is do not try to justify that it was ok for DAL pilots to do the deal they did and now that the same deal UAL is somehow a whole new concept. Fact is again you already had 76 seaters before getting one 717, we will end up getting the same number before we get the new narrow body.
We have a hub in SEA (or crew base, not really a hub per se' in the contract, but two different fleets are based there---7ER and 330) because of the AK codeshare. We fill DL widebodies to Asia and Europe with the gates allotted. There are not enough gates left there to compete adequately against AK domestically, but for INTL feed DL does very well. How does USAir help you again? Not as much.
Your E195 rates are a lot less than the Airbus rates, and the Airbus were already hinted at possibly leaving your fleet. So, you go down A LOT if you dump your busses for cheaper E195s or C-Series. We are parking some 757s for 739s, but that is a $5 an hour difference, and also some 739s will replace some older 320s, so that is an increase in pay. But, yours could be a huge hit if that comes to fruition, and some people think it might.
Looking at your point about the 76 seaters, try not to fool yourself, the 70 seaters take up the SAME AMOUNT OF ROOM AT THE GATE as a 76 seater. Your Dash-8-400s do the same. It takes up a whole gate. Adding a few more seats really means adding a few more first class seats. Now, if you need to start over with zero 76 seaters all the way to 153 or whatever, well, that is YOUR fault for negotiating that. Your combined MECs saw value in other things, and try to lay blame on DL, when it is your decision. You have just as many 70 seaters (66 seaters), and probably more 50 seaters (or you will soon). It is your vote. Vote wisely. The majority at DL voted this way because they saw the 88 717s there, the better ratio, the tighter scope, the pay raise, and only 3 year duration. Let's hope you do better if you don't like the current one.
Bye Bye---General Lee
