jetflyer
Concerned Citizen
- Mar 8, 2002
Jammed Elevator
Do you guys that are speculating C.G. and weight remember that the plane had MAINTENANCE on the Trim tab 3 days before the crash!!!??????? HMMMMMMM and that the flight data recorder said that the elevator had been moving eratically for the previous seven flights out of maintenance.
The FAA will find that the elevator jammed, cable slipped a pulley, etc. Most likely though the truth will never be known.
An aft c.g. or being overweight might just be pure coincidence.
