BE-90 weight?
Captain4242
Can anyone tell me the weight of a King Air 90?
I know all planes are a little different; round numbers are ok.
Thanks.
Depends on which models, too. We have both C-90s and C-90As... Empty weights for both are around 6400lbs, give or take a bit. Straight C-90 max gross = 9650 (ramp 9705). C-90A (and probably later models) is 10,160 ramp, and 10,100 max gross.
Edit: BTW, ours are setup for EMS, so the Empty Weight may or may not be quite a bit different than a conventional C-90. Just FYI.
I fly a C90A and a C90B and the weights are 6917 and 6879 resp. Max ramp is 10150 and T.O. is 10100 for both.
10,500 max t/o c-90A
546 gallons of gas 2600 ;bs gas. usually 500 lbs usful after full fuel
BE-F90 - 10,950 MTOGW, 7062 BEW, aft potty seat in baggage compartment, high float gear, 470 gal total fuel
