oldxfr8dog said:
Never heard of this particular exemption, could you elaborate on the restrictions?
Flight Operations Bulletin
Subject: Exemption 8575
Background
The long-standing domestic IFR/NO ALTN criteria (the “1-2-3 rule:” within +/- 1
hour of ETA, a reported or forecast ceiling of at least 2000 feet and a visibility of
at least 3 miles) predates many advancements in aircraft/airport approach
technology, pilot/dispatcher training, weather forecasting/monitoring and other
dispatch technologies.
Recognizing the modern capabilities of Delta's fleet and dispatch operations,
the FAA has granted Delta conditional relief from the above criteria in the form
of Exemption 8575. Under the conditions and limitations listed below, the use of
Exemption 8575 can begin on August 15th.
Exemption 8575 (“1-1-2 Rule”)
No alternate airport is required if for 1 hour before and 1 hour after the
estimated time of arrival at the destination airport, the appropriate weather
reports or forecasts, or any combination of them, indicate:
• The ceiling will be at least 1,000 feet above the airport elevation; and
• Visibility will be at least 2 miles.
Limitations
• When dispatching under Exemption 8575:
– The destination airport must have an operational CAT II ILS approach for
an anticipated landing runway; and
– The aircraft must be CAT II capable; and
– The flight crew must be authorized to conduct the approach.
• Dispatch is not permitted under Exemption 8575 at any airport where
thunderstorms are forecast in either the main body of a weather forecast or in
the remarks section of the forecast or reported between 1 hour before to
1 hour after the estimated time of arrival.
• Use of this exemption is limited to airports in the contiguous United States.
• A dispatcher remark must be issued on the release advising, “Flight
dispatched under Exemption 8575.”
Note: After dispatch if any of these conditions change, the flight may proceed
provided the Captain and Dispatcher agree that current conditions would not
preclude a safe landing.
Number: 05-07
Date: August 15, 2005 Page: 2 of 2
Conclusion
The use of Exemption 8575 will allow Delta to take further advantage of modern
OCC and flight technologies to reduce fuel expense while maintaining a high
margin of safety. The exemption will guarantee at dispatch there will be at least
900 feet and 1 3/4 miles visibility buffer between approach minimum and
forecast conditions.
Feedback
Pilots flying under Exemption 8575 are encouraged to provide feedback. The
Captain should contact the Dispatcher with any immediate operational
concerns. All issues can be subsequently addressed via a COR under the
category “Aircraft.”
The full text of FAA Exemption No. 8575 is available on the Deltanet under “Pilot
Tools.”
FOM Incorporation
The information in this bulletin will be incorporated into the FOM during the next
revision cycle (Revision 22, December 1, 2005).
